Brake Q's
Old Jun 28, 2004 | 03:35 PM
offroadbronco's Avatar
offroadbronco
Brake Q's
I know this issue has been beat to death but please bear with me. Got a 77 F-100 with manual brakes. I just got a new m/c and brake booster and I want to know what I need to bolt it on. I see that most have brackets that put the booster about 4-5 inches off the firewall. Will I need this or can I bolt dirrectly to the firewall. Also will I need another pedal assembly or linkage rod or can I get away with stock. If I do need a mounting bracket, can somebody give me the dimensions so I can fab one up.
Old Jun 28, 2004 | 03:39 PM
Torque1st's Avatar
Torque1st
Posting Legend
Pull the parts you need from a junkyard truck. You don't need to fab anything.
Old Jun 28, 2004 | 03:51 PM
offroadbronco
My local junkyard is real weird when it comes to pulling parts, they only sell certain parts and if I can just make something, it is better than trying to deal with those a-holes. All I really need for the bracket is the distance from firewall to booster mount and I can add a 2" tab on each end to bolt to.
Old Jun 28, 2004 | 03:55 PM
Torque1st's Avatar
Torque1st
Posting Legend
Find another junkyard, there are lots of them. The better junkyards for these old trucks are out away from cities. You will need to find another junkyard anyway to keep your truck running.
Old Jun 28, 2004 | 04:00 PM
offroadbronco
I live way out in the country, only got two junkyards, the other one doesn't have what I need, I already checked. but thanks anyways
Old Jun 28, 2004 | 04:06 PM
offroadbronco
If anybody could just give me the length of bracket between firewall and booster, i'd appreciate it.
Old Jun 28, 2004 | 09:26 PM
ungerp's Avatar
ungerp
Brake Q's
I am enountering a similar problem with my 1974 F-100 4x4. I purchased the booster and master cylinder and now need the mount and a rod to connect the pedal. I found an aftermarket mount, but would prefer the original and rod assembly. Are there any sources known by anyone and do I just need the mount and connecting rod or also a different pedal?
Old Jul 17, 2004 | 04:34 PM
ungerp's Avatar
ungerp
Brake Booster Fix
To everyone who has been having problems or questions regarding upgrading to the power brake vacuum booster for your early Ford. I had found an adapter from Chassis Engineering, bur rather than pruchase it I fabricated my own. I used a 3 inch piece of 2 1/2 black pipe and two pieces of 1/4 plate steel. I cut one to match the original two bolt mount to the firewall, formed similarly to that of the original master cylinder. The other plate was square to mount the new vaccuum booster to it. Once all the holes were drilled and cut for the pushrod to pass through I welded the plates on either end of the pipe keeping all square to each other and all mounting holes aligned to keep the booster level and square. The length of pipe could be longer, but not much so you don't cover up all your left engine bank. Now for the pushrod. My booster had a rod installed which required a fine thread 7/16 inch bolt. Using a 2 inch long bolt I welded a piece of the original banjo bolt from the old master cylinder to the bolt less the head. This worked great and if you make it just a little long you can adjust your pedal height. End result, brakes that stop my F-100 with 35" BFG mud terrains with complete ease. If anyone wishes for more details etc you can contact me at pat.unger@outb.com.
PA F250
Aug 11, 2018 05:00 PM
lilrobo
Jul 6, 2013 09:12 PM
Rob C
WTB - Parts & other
Jan 10, 2011 11:45 AM
BigMikeUGA
Jan 4, 2011 07:53 PM
boathaulin76
Jun 22, 2009 01:05 PM
