Miswired hitch plug?
Old Jun 28, 2004 | 03:00 PM
tombob's Avatar
tombob
I have a 1980 Ford Bronco. It came with a hitch and a plug. The plug is the standard flat plug with four wires leading from it. When I hooked it to my trailer all the lights worked except that when I press on the brake, the trailer lights go off. Upon investigating. I saw that the white wire from the plug on the truck was dead-ended; it was not connected to anything--just some electrical tape wrapped around it. Only three wires looked to be wired into the truck wiring--a green, a brown and a yellow.
On my '95 Dodge van, the white wire is connected to something in the van wiring. All lights on the trailer work when the trailer is connected to the van.
What gives? Where should the white wire be connected into the Bronco wiring?
Old Jun 28, 2004 | 09:12 PM
Dealford's Avatar
Dealford
Green is right brake/turn signal. Yellow is left brake/turn signal. Brown is running lights. White is ground.
AL.
Old Jun 29, 2004 | 12:50 AM
kioolt's Avatar
kioolt
Like Dealford said the white wire is the ground. I've seen it not hooked up several times. I always hook it up to ground. Most people depend on the hitch connection for ground. If you were checking the trailer lights out without the trailer hitched at the time, that could be your problem.
Old Jun 29, 2004 | 08:42 AM
tombob's Avatar
tombob
I did check with the trailer hitched. I even took the nconnected white wire and connected it to the hitch and it did not help.
The white wire on the trailer-side plug is grounded to the trailer frame. I even disconncted it to see if that woudl help but it did not.
This has me really stumped. Any suggestions? If I don't get it fixed with my luck I will get a ticket.
Old Jun 29, 2004 | 04:48 PM
Knight70F250's Avatar
Knight70F250
Not to hijack the thread, but would the color coding on a '70 CS be the same in the camper yoke as far as the lights on a trailer? (Yoke comes up behind cab). I know that there are more wires in there, but I just need to hook up my old boat trailer so I don't get a ticket either. Thanks.
Old Jun 29, 2004 | 08:58 PM
Beast12's Avatar
Beast12
Just hook it to the frame somehow. With a eyelet or something. That is for sure 100% the problem! Good luck!
-Matt
Old Jun 29, 2004 | 09:30 PM
Dealford's Avatar
Dealford
I don't have any info on your truck but a test light will tell you what your existing wires do, brake/signal(R or L), parking(running) and there may also be a direct 12v which would run accessories in the trailer.
Is your trailer plug 4 or 7 pins? You could build an adapter using the 7 pin male to plug into the truck(if you have the 7 pin female system on the truck now) and only run 4 wires from it-green=right, yellow=left, brown=running & white=ground. Whatever plug the trailer has on it, buy the other half for the truck & hook it up accordingly.
Have you checked the colour coding of the wires on the trailor? You can use your truck battery and 2 jumper leads to light up the lights.
As far as the ground wire issue goes, bolt both the truck half and the trailor half ground wires to their respective frame. Make sure that the point where you attach the ground lead is CLEAN & free of rust. Use lots of dielectric grease/silicone to seal it up good.
AL.
Old Jun 30, 2004 | 08:38 AM
BieselDiesel's Avatar
BieselDiesel
Have you checked the wire on the truck side? Disconnect the 4-wire connector and get you a 12V test light. Have some one turn the running lights on, you should show power on the brown terminal. Now check you yellow and green, which are the turn signals. Now hit the brakes. The yellow and green also serve as the brake. Check the truck first and see if you get anywhere. Also, have you check the lamps in the trailer, maybe out?
Old Jun 30, 2004 | 06:14 PM
Knight70F250
Thanks for replies. I have a seven pin hookup on truck. The mate went with the camper when I junked it (they wouldn't let me have it). I guess the smart thing to do would be to get a new matching set and just hook the four wires from the trailer into their correct slots, and the seven from the truck into theirs and all should work fine. Colors on truck are same as mentioned plus some others. Wires on trailer are old and painted over, but can easily be traced from fixture to hitch so I don't see any problems. I'll just splice new color correct wires onto trailer and that will be that. Thanks again. Guess I should have posted here in the first place.
