Gas Tank Replacement
On both of the tanks it reads empty. I get little movement on the gauge needle. The rear tank will read slightly above "E" and the front one reads slightly below "E".
Can I assume that both sending units should be replaced or are their other prblems that I am not aware of?
If I have to replace the sending units I will want to change the tanks as well, do a swap out if you will. How do I determine what size my tanks are? The rear one is a regular square tank but the front one is a long, side mounted one.
Also, there is a vent valve in the middle of each tank. What is it for and how do I replace it?
Any help would be appreciated. You can e-mail me directly if you wish to.
Thanks
wmodon
ljmacad@netzero.com
If both checks are okay and your fuel gauge still doesn't work, I would suspect the gas gauge itself. I have seen them go many times but no where near as common a problem as corroded wiring and/or connectors.
