caliper pins
Old Jun 26, 2004 | 12:02 AM
got_zuk's Avatar
got_zuk
Exclamation caliper pins
has anybody had a problem with a siezed caliper pin? both of the bottom pins on the front are siezed and I can't figure out how to get them out.....I am leaving sunday to drive 5 hrs back to NC from SC and am trying to fix it before I leave...any thoughts or tips would be greatly appreciated...the other problem is has anybody had a bad vibration problem at high speeds with the Pirelle scorpion recall replacement tires?
Old Jun 26, 2004 | 12:40 AM
mudman00x's Avatar
mudman00x
had the same problem, had to buy new brackets and pins. about 95 bucks a side
Old Jun 26, 2004 | 05:17 AM
KaaYooN's Avatar
KaaYooN
Caliper pins froze in my truck. I removed the bracket and placed the pin in a vice and twisted the bracket, worked it off the caliper pin.
Make sure u use anitseeze when u install the caliper pin back on.
Old Jun 26, 2004 | 08:55 AM
got_zuk's Avatar
got_zuk
anti-sieze yes!!!! Thanks for the info, couldn't do much last night in the rain but will be working on it today!!! Thanks, Brian
