Engine Breather & Performance problems
Old Jun 25, 2004 | 10:15 PM
ZUMMAK1's Avatar
ZUMMAK1
Question Engine Breather & Performance problems
Say I Just Picked Up Another F-100 Pickup 1978.
I See A Breather Hose Running From The Right Rear Side Head Valve Cover To
The Front Side Of My Carburetor. I Also Have A Oil Filler/breather Cap On The Left Side Valve Cover With Elbow Pc Value Coming Out The Top Pointing Towards The Carburetor.
My 1st Question Is:
Should I Be Thinking About Getting A Hose And Clamps And Tie Pc Valve And Tying Into The The Other Hose?
2)
My Red 78 Ford Pickup Has Alot Of New Parts On It. New Spark Plugs And Wires Along With All New Fluids And Such. But Every Once In A While. I'll Be Running Down The Road Doing About 55. And She Will Just Die On Me. I'll Get It Over To The Side Of The Road And Put It In Part And Turn The Key Over And She'll Start Right Back Up. And Will Run For
A Day Or Two And Then It Will Happen Again.
Should I Be Thinking About Getting A New Or Rebuild carburetor?
Old Jun 25, 2004 | 11:12 PM
Mil1ion's Avatar
Mil1ion
The driver side valve cover houses an oil filler cap.
The passenger side valve cover is the spot for the PCV valve which runs to the BACK of the carb
Old Jun 26, 2004 | 02:53 PM
LxMan1's Avatar
LxMan1
Depending on the engine that you have, The PCV valve should be in the drivers side oil fill cap and connected to the front of the carb. The passenger side should have an elbow and hose that runs to the factory air cleaner to a breather filter inside of the air cleaner.
Old Jun 27, 2004 | 02:20 AM
77460ford's Avatar
77460ford
When you say the truck dies, do you mean stutters to a stop or suddenly cuts out? If the truck suddenly cuts out one culprit can be the ignition switch. They get older and can short out, its a cheap fix if thats the problem.
John.
hooler1
Apr 16, 2011 11:00 PM
Richard Worley
25
Apr 8, 2005 09:35 PM
79RangerJoel
Aug 28, 2004 03:49 PM
jerrycarl
Mar 4, 2004 07:03 AM
tapenick
Feb 17, 2003 09:23 PM
