1995 Explorer
Old Jun 25, 2004 | 05:54 AM
TheViper90210's Avatar
TheViper90210
1995 Explorer
I have looked everywhere on how to disable the beeping in the driver side door when the keys are still in the ignition and the door is open. Could someone please tell me how to disable the beeping or give me a link to a site that says how>>??? I have a 1995 Explorer
Thanks
Old Jun 25, 2004 | 02:05 PM
TheViper90210
I just want to know like where the wire is that makes the beeping noise in the door when the doors ope and key in ignition, Where is that WIRE?
Old Jun 25, 2004 | 02:24 PM
prcrboy's Avatar
prcrboy
the switch is built into the door latch in the door. Most of us just use a screwdriver to close the door latch and open it before closing the door. The wire runs out the door and into the kick panel behind the door.
Old Jun 29, 2004 | 08:58 PM
TheViper90210
does anybody else know of a code or sequence you can do to disable the beeping in the drivers door, or just where is the wire and what color is it so i can cut it?? PLEASE HELP!!!
Old Jun 29, 2004 | 09:38 PM
e-manfive's Avatar
e-manfive
noisy door chime,(reply)
I also have a 95 expl. I had to pull off the door panel and unplug one or two of the wires hooked to the door latch. This won't get rid of the whole chime, but it will go off after 2 or 3 seconds. You may try getting to the little box where the chime comes out from in the middle of the console. You may have to see which wire goes to the noise maker. You may also try unplugging the seatbelt plug underneath the driver's seat. Hope this helps!
Old Jun 29, 2004 | 09:47 PM
jclj2003's Avatar
jclj2003
Under The Steearing Colom Thier Is A Black With Pink Strip Thin Wire That Has A Connector Right Before The Plasic If U Onplug It Gos Away I Did This When I Was Puting In My Alarm And Remote Starter Annoying
Old Jun 29, 2004 | 10:37 PM
TheViper90210
thanxs ill try this stuff tomorrow and let yall know if i got it
Old Jun 29, 2004 | 10:41 PM
TheViper90210
I also had another ? if anybody knew why on my 1995 Explorer when i have a cd playing and turn off the car, how come the song starts over when i turn it back on, because I know in other Fords it will pick up where left off on the CD, is it just because its a 95 or what, if anybody has any idea if it could be fixed please let me know!! and how!
