cat problem?
Old Jun 24, 2004 | 10:44 PM
skelator's Avatar
skelator
cat problem?
ok, here is the problem, my 84 bronco with carbed 351w runs great for about five to ten min until it gets up to temp and then dies. i talked to some people and i have heard that a clogged exhaust can suffocate the engine and make it die, it has two inline cats on it and as far as i know they are oem. i would take them loose to check for myself but, alas they are welded on. the question is how likely is it that they are my problem?
Old Jun 24, 2004 | 11:19 PM
351M's Avatar
351M
could also be caused by the coil, just had that happen to me a few weeks ago, it would get warm then there would be an open circuit in the windings.
Old Jun 24, 2004 | 11:20 PM
skelator's Avatar
skelator
oh, forgot to mention i have replaced the entire egnition system, carb, fuel pump, and fuel filter
Old Jun 25, 2004 | 12:19 AM
351M's Avatar
351M
Could very possibly be the cat then one of the cats then altohough i have never seen that happen.
Old Jun 27, 2004 | 02:05 AM
kens64's Avatar
kens64
Tap the cats with a hammer and listen for any rattles. If they do, they are toast. Parts of the cat can also come undone and clog your mufflers too.
If they are going bad, you probably should have noticed performance dropping over a period of time, as they come apart and clog.
Old Jun 27, 2004 | 03:05 AM
skelator's Avatar
skelator
thanks for the info, i will try that, i just got it recently and am trying to fix everything at once.
Old Jun 27, 2004 | 06:21 AM
73GreenF250's Avatar
73GreenF250
I have a buddy who had an 80s dodge with a 4 banger, and the cat got clogged. the engine got so hot it cracked the head, so you should check it out as soon as possible. I hate driving my truck when i think there might be something wrong with it
Old Jun 27, 2004 | 04:40 PM
skelator's Avatar
skelator
i am the same way, since my entire exhaust system is welded up, i was thinkin about unbolting it from the header and ramming a coat hanger down in there to see if i couldnt break somthin loose. what would happen if the thermostat i put in is too low a temp?
