1978 - 1996 Big Bronco
exhaust dumps
Old Jun 24, 2004 | 09:20 AM
LEIGUY's Avatar
LEIGUY
exhaust dumps
i have a friend whohas a like 9 mach one stang and has what he calls exhaust dumps right after the headers...they are a y shaped pipe and can be directed to the cats and muffler of directed directly outside, bypassing everything else ....he uses a choke like system to do it.......has any one seen or heard of anything like that for a 90 351 bronc and where i could get somehting like that......its just to cool....his exhaust sets off car alarms and id like to have that sound every now and the easily.....thanks guys
Old Jun 24, 2004 | 09:21 AM
LEIGUY's Avatar
LEIGUY
ehem....69 mach 1
Old Jun 24, 2004 | 10:21 AM
kameronth's Avatar
kameronth
I know Jegs carrys them but they are kind of expensive(like 50 bucks a pop). I know JC Whitney used to carry them for about 25 dollars each but it has been a while since I have looked at one of there magazines so I am not sure.
Old Jun 24, 2004 | 10:49 AM
Will_01_GT's Avatar
Will_01_GT
I don't know "about having some thing to set off car arlarms" being a mod I'd love to have, but to each his once, Any ways the dumps on his Stang are basically turn downs in place of mufflers, Most people don't use the mufflers at all. And all those exhuast fumes are going to end up in YOUR cabin. Disconnect your muffler for a while and you'll see what I mean about the exhaust. I'd be interested if you do the mod, take pictures and create a sound bite if possible.
Old Jun 24, 2004 | 11:18 AM
Kemicalburns's Avatar
Kemicalburns
you will be way loud , loose alot of backpressure and have no low end. your friend needs this because hes pushing some serious hp and the exhaust needs to breath better but for you sounds like a waste of money.
late
Old Jun 24, 2004 | 12:30 PM
LEIGUY's Avatar
LEIGUY
ok...thank you all for the advice...it helps and after hearing yalls opinion i done think im gonna do it
thank yall
Old Jun 24, 2004 | 12:31 PM
LEIGUY's Avatar
LEIGUY
i just need a bigger sound from my bronc and i cut off the muffler and am not satisfied....i was thinking about getting rid of a cat and putting the muffler on...what do yall tyhink
Old Jun 24, 2004 | 12:33 PM
LEIGUY's Avatar
LEIGUY
a little more power would be nice...im sporting an intake and msd ignition...any other suggestions...exhaust wise or other
Old Jun 24, 2004 | 12:34 PM
Kemicalburns
I would go headers with single 3" out the back with what ever muffler you want. I am running a flowmaster and am very happy with it.
Old Jun 24, 2004 | 12:35 PM
LEIGUY's Avatar
LEIGUY
why not dual
Old Jun 24, 2004 | 12:39 PM
Kemicalburns
cause you cant run true dual on our broncos. tcase and cross member get in the way. they do have the cat back systems but they only simulate dual exhaust. it can be done but personally i like the factory design less to get damaged when out playing and the single performs better then duals anyways.
Old Jun 24, 2004 | 12:53 PM
Will_01_GT's Avatar
Will_01_GT
Ya, I'm with kemicalburns on this one. Get the headers and Flowmaster 40 series or maybe these from Flowmaster I bet these would sound sick !
http://www.flowmastermufflers.com/cg...ster/race.html
Old Jun 24, 2004 | 12:55 PM
LEIGUY's Avatar
LEIGUY
so you think i will actually lose power with the cutouts
Old Jun 24, 2004 | 12:57 PM
Kemicalburns
yea, you get torque from backpressure. if your exhaust flows to freely then you will lose low end. low end is what moves our 6k lb rigs
Old Jun 24, 2004 | 01:15 PM
LEIGUY's Avatar
LEIGUY
so i f i got a high flow cat id lose backpressure too?
so the best way i could improve my exhaust is long tube headers and a single outlet flomaster
