90 econoline conversion van fuel selector
Old Jun 23, 2004 | 07:03 PM
dbc2004's Avatar
dbc2004
I am new to Ford Enthusiasts. I just purchased a 90 150 econoline van. The previous owner said that the rear tank 'doesn't work.' After filling the rear tank, I switched the selector to rear and the fuel level reads as empty. I left it switched to rear tank and drove 100 miles, but it just took gas out of the front tank. I think i need to replace the selector valve. Is there any way to field test it?
Old Jun 24, 2004 | 06:19 PM
Mustang 5.0's Avatar
Mustang 5.0
a couple of useful urls.....
https://www.ford-trucks.com/forums/s...d.php?t=240093
https://www.ford-trucks.com/forums/s...92#post1621992
http://www.stangler.com/motorsports/...alve/index.htm
OK. pictures and theory on how the valve works are here.
http://www.stangler.com/motorsports...Valve/index.htm
to test, just unplug your fuel tanks lines from the valve, and switch the ignition switch to on, and toggle the selector switch. fuel will pump from the tank to the ground.
Old Jun 26, 2004 | 12:00 AM
dbc2004's Avatar
dbc2004
1000 thanx
Thank you for the help. I'm going to test it over the weekend.
