Sponsored by: Innova
instead of Dynamat...
Old Jun 23, 2004 | 05:24 PM
snakebit's Avatar
snakebit
Does anyone have experience with this product instead of paying big $$$ for Dynamat extreme (if I hear of one more 'extreme' product I am going to vomit ).
Ebay item #5706068274
120 bucks for 100sq ft with free shipping.
I've got a F250 CC and need to do the foor doors and panel behind the back seat. Probably double coat all of it.
What do you guys think?
Old Jun 23, 2004 | 07:59 PM
snakebit's Avatar
snakebit
Or any other brand of sound deadener that you ahve had a good experience with.
Old Jun 23, 2004 | 10:59 PM
drewcoolness99's Avatar
drewcoolness99
looks decent. I would go for it. I kinda like trying lesser known stuff. I might end up gettn some when i have some extra money. Its even got free shipping
Old Jun 23, 2004 | 11:23 PM
kens64's Avatar
kens64
Search the web for stuff called "brown bread". There is also some nifty stuff at Lowe's made for roofing. Pretty cheap too. Cant remember the name, but it shouldnt be hard to find. Its in a 6"-8" tall roll, and its silver.
Old Jun 24, 2004 | 12:18 AM
drewcoolness99
the lowes stuff work well?
Old Jun 24, 2004 | 12:22 AM
kens64's Avatar
kens64
Works pretty good. A heat gun will make it stick and bend much easier, but its not needed.
Old Jun 24, 2004 | 12:25 AM
kens64's Avatar
kens64
Just found the name of it. Peel and Seal.
Old Jun 24, 2004 | 02:13 AM
drewcoolness99
wow the brown bread is as much as dynamat if no more
Old Jun 24, 2004 | 08:43 AM
snakebit's Avatar
snakebit
Does the roofing stuff and Lowe's/Depot smell bad though?
Probably asphalt based?
Old Jun 24, 2004 | 01:45 PM
kens64's Avatar
kens64
I didnt have a problem with smell in my car. Im gonna use it on the truck when I get started working on it. I assume the more you use, the more it might smell. I thought Dynamat had a much stronger smell.
Old Jun 24, 2004 | 01:47 PM
kens64's Avatar
kens64
Thats strange, they must have raised the price. The last time I bought some, it was quite a bit cheaper.
Old Jul 10, 2004 | 03:57 PM
stealth1's Avatar
stealth1
Thumbs up
Yes I have, I bought the same kit from the same person. I have used dynamat as well. That stuff works great. I could not tell a difference except price. I did use 2 layers. The guy ships super fast and there is enough on that roll to do ALOT!!! I would say get it, you won't be sorry. I used as much as I could and still have enough to do my wifes explorer in the future.. The back panel really needs to layers. The doors were kinda hard to get 2 layers on and install the panels afterwards.Just a thought..
Old Jul 10, 2004 | 04:00 PM
kens64's Avatar
kens64
Here is another alternative to Dynamat. Its very cheap. I bought about $20 worth and did both front doors on my Contour, with some left.
http://www.partsexpress.com/pe/showd...number=268-030
Old Jul 10, 2004 | 04:50 PM
FAB150's Avatar
FAB150
I use the Peel n Seal from lowes and it works great. for about 60 bucks i did every inch of my 98 f150 but the roof. my previous car i used the dynomat extreme and between the two i can hear no differance.
Old Aug 14, 2004 | 12:31 PM
spicy429's Avatar
spicy429
I'm doing a full install on my 99 Explorer Sport and didn't want to pay outrageous bucks for sheet sound damperers.
I went with a product called QuietCar. It's a liquid that can be brushed, rolled,
or sprayed on. I sprayed it on but the method of application has no effect on the products performance according to the manufacturer.
I went with 8 coats on the floor, 6 on the interior metal walls, 5 on the doors, 3 coats under the hood, and 2 coats on the backside of all interior plastic panels. Nothing on the roof yet, I didn't want to remove the headliner.
It took a while but the results are unbelievable. Dead quiet and it doesn't stink when the vehicle is sealed up tight under the sun like Dynacrap does.
It's been a while since your post so I'm probably too late to help, but I hope you've had good luck with whatever method you've chosen.
