Alternator Question FBp????
Old Jun 23, 2004 | 10:37 AM
Al_V's Avatar
Al_V
FordBoyPete,
I remember you having some good advice on Ford Truck alternators, maybe you could help this guy:
https://www.ford-trucks.com/forums/s...d.php?t=253488
Thanks
Old Jun 24, 2004 | 12:15 PM
FordBoypete's Avatar
FordBoypete
DONE. . . . . . . . . .
FBp
Old Jun 25, 2004 | 10:35 AM
Al_V's Avatar
Al_V
Thanks,
But how bout details, If I want to buy the "older 100a external system with digital-electronic V-Reg is only way to fly" what year and model Ford should I reference?
Thanks again,
Al
Old Jun 25, 2004 | 02:02 PM
Putt's Avatar
Putt
Al- I think I can help The 100a external reg. alt was used on cars and trucks in the early '70's until the mid '80s. Look for a large case alternator with a formed plug-in with two wires on the rear side of the case. The large charge wire is separate. It takes diff brackets I believe due to case size.
The electronic regulator is stock replacement on any Ford from the aftermarket. Just make sure that the cover says electronic and is short.
FBp will correct me if I'm wrong!
