transmission problem?
Old Jun 23, 2004 | 08:02 AM
archibald's Avatar
archibald
The first, excuse my English. And now I would like to explain my problems.
1. If I am going down from a hill, stop, engage R and trying back a car up to hill without breakes on the car is moving down the hill. Is it normal or there should be some tranny problem.
2. I can hear some noise (only if window is opened) in engaging from D (or 1,2) to R.
Thanks for your replyes.
Old Jun 23, 2004 | 09:02 PM
FTE Herman's Avatar
FTE Herman
Archibald, if I understand you correctly, you are stopped, facing down hill, and in Reverse. If you take your foot off the brake, the vehice will continue to roll down the hill. If the hill is steep enough, this is normal. Now, if you apply the accelerator, you should back up the hill. This is due to the slippage in the torque converter.
If you do not understand this, tell me what your native language is and I'll try to translate for you. (I am a cunning liguist)
Old Jun 24, 2004 | 01:09 AM
archibald's Avatar
archibald
Thanks for your reply. I understand this very well. I just did not expect there was a slippage in torgue convertor.
But If you want to make some excersise you can try to translate it to Czech.
Old Jun 26, 2004 | 09:14 PM
FTE Herman's Avatar
FTE Herman
This is as close as I can get:
Archibald, åñëè ÿ ïîíèìàþ âàñ ïðàâèëüíî, òî âû îñòàíîâëåíû, ñìîòðÿ íà âíèç ñ õîëìà, è â îáðàòíîì. Åñëè âû ïðèíèìàåòå âàøó íîãó ñ òîðìîçà, òî vehice áóäåò ïðîäîëæàòüñÿ ñâåðíóòü âíèç ñ õîëìà. Åñëè õîëì êðóò äîñòàòî÷íî, òî ýòî íîðìàëüíî. Òåïåðü, åñëè âû ïðèêëàäûâàåòå àêñåëåðàòîðü, òî âû äîëæíû ïîäïåðåòü ââåðõ ïî õîëìó. Ýòî äîëæíî ê ñìåùåíèþ â êîíâåðòåð âðàùàþùåãî ìîìåíòà.
Oh well, wont take Cyrillic.
