Sponsored by: Auxito
Cat rattle
Old Jun 22, 2004 | 08:29 PM
stantojl's Avatar
stantojl
Cat rattle
Both of the rear cats rattle pretty bad whenever my 97 F150 (4.7L 4x4) is sitting at an idle. It only does it when it is sitting stopped and in gear with either the air or heater on. It doesn't do it if you put it in park or turn the heater/air control **** to off. It seems to be the outer shroud that is on the rear cats that is making the noise. The shrouds seem to be vibrating. It can get pretty loud. I have checked all the clamps and the motor mounts and everything is tight. I recently replaced the engine and it didn't do it with the old engine. The new engine is running great and smooth. Anybody ever come across this problem or have any ideas?
Old Jun 22, 2004 | 08:48 PM
Racerguy's Avatar
Racerguy
If it is just the shield on the convertor that is rattling, and usually it is, you can get big hose clamps from your Ford dealer that fit around the convertor to hold the shield tighter.
Old Jun 29, 2004 | 06:47 AM
stantojl's Avatar
stantojl
Its definitely the shields rattling. I put three hose clamps on the drivers side cat and it still rattles. Any other ideas/suggestions?
