Getting Code 334
Old Jun 22, 2004 | 01:01 PM
marvoles's Avatar
marvoles
Getting Code 334
HIall,went to advance auto to check my codes and only one thay found was a code 334
[single voltage higher then expected ] do i need a new egr valve?? any help would be great, thanks mavoles,93 ranger2.3 5pd,
Old Jun 22, 2004 | 01:35 PM
NightReaver's Avatar
NightReaver
I have a 96 2.3L
that sounds awefully familiar....
I have had my erg valve replaces along with a filter in that same area..
have the dealer at least look at it
(it's only $75.... ha ha)
Old Jun 22, 2004 | 04:01 PM
Ken00's Avatar
Ken00
Here are some possible causes, you should really run the pinpoint test for the code, drop me an email if you need it.
Possible Causes:
-- Improper vacuum.
-- Improper exhaust backpressure.
-- EGR valve.
-- EGR leakage.
-- Low or no EGR flow.
-- Wrong orifice.
-- EGR system components.
l Check vacuum hoses and connections for looseness, pinching, leakage, splitting, blockage and proper routing.
l Inspect EGR valve for loose retaining bolts or damaged flange gasket.
Thedonk
47
Jun 22, 2016 11:52 AM
musicars
Sep 29, 2015 12:30 AM
MEDIC2035
18
May 8, 2013 01:31 PM
