91 Ford Explorer stalling when cold --
Old Jun 22, 2004 | 01:03 AM
morrisey96's Avatar
morrisey96
Hello -
I have a 91 V-6 Explorer that -
(1) Starts up and drives fine for the first few minutes
(2) After a few minutes (and before the temp guage starts to register) it will die as you try to accelerate unless you "jazz" the throttle. Feels just like a broken accel pump on a carburated car.
(3) As soon as the temp starts to register everything returns to normal and it drives just fine.
I receive a Temp sending unit out of range error code even though I have tried two new senders. (the one next to the thermostat).
Any suggestions will be greatly appreciated -
Steve
Old Jun 22, 2004 | 12:52 PM
mrshorty's Avatar
mrshorty
1) What code number for the bad ECT? Is it KOEO hard fault, KOER, or continuous memory?
2) Did you run the self-test with the engine warmed up? A lot of times, the ECT code is a result of running the self-test on a cold engine.
Before replacing the ECT, did you verify that the wiring between the ECT and PCM is ok? Trouble code point to circuits, not sensors. The computer can't look down through the wiring to see a bad sensor. It can only "see" what's right there in its face.
3) Did you replace the correct temperature sender? Your '91 (if it's like my '92) has two temperature senders: one feeding the dash gauge (single wire connector) and one feeding the computer (has two wires in the connector).
Old Jun 22, 2004 | 01:17 PM
morrisey96's Avatar
morrisey96
mrshorty -
Wow, thank you for the reply - you obviously are an expert on this.
(1) Don't remember the code # but it was during a KOER
(2) Engine was warmed up during test
(3) I think you have identified where I went wrong. I replaced the single wire sensor - I thought it strange that the temp guage could perform normally if the sensor was indeed bad. I do not see the two wire sensor you mentioned - where is it located.
Thank you for your help -
Steve
Old Jun 22, 2004 | 04:11 PM
morrisey96's Avatar
morrisey96
BTW - I found my notes - it was a code 21 !!! Still can not find the two wire ECT (I did find a two wire ACT on the manifold)
Steve
Old Jun 22, 2004 | 05:31 PM
mrshorty's Avatar
mrshorty
The ECT is essentially the same sensor as the ACT (Might even interchange, not sure). The ECT should be located near the dash temperature sender on the intake manifold. If I remember right, it's tucked up underneath the throttle body.
Old Jun 22, 2004 | 07:50 PM
morrisey96's Avatar
morrisey96
Thank you , I will check it out !!
Steve
IHateCommieCars
Jan 29, 2015 04:43 PM
Gomer Fackworth
Nov 19, 2008 08:59 PM
nudgey
17
Feb 4, 2005 04:10 AM
jldunn80
Jan 13, 2004 12:49 AM
cpfenn
Jul 5, 2003 08:37 PM
