The important thing to keep in mind on any replacement air intake is making sure it is relying on cold air, not hot under the hood air whick will gain you little to nothing except more intake noise!
A inexpensive alternative to the overpriced air intakes is to buy the K&N drop in filter for your factory airbox and then wrap the entire intake and box all the way to your throttle body with thermal insulation tape. The HP increases are almost identical to a complete cold air intake system for much less $$.
