Aftermarket Products
Sponsored by: Worksport
Air Intake for 5.4L problem!!!!
Old Jun 21, 2004 | 06:49 AM
55FordLover's Avatar
55FordLover
okay,
installed an aftermarket intake system on my truck and now the service engine soon light is on....noticed that there was an additional sensor on the original air intake....from the air filter...the new intake only has one sensor port...installed the litte rubber mounted sensor but left the other one off? SO what does that sensor do? what can i do now to close the circuit?
James
Old Jun 21, 2004 | 03:46 PM
xallxforxchristx's Avatar
xallxforxchristx
I recently installed a Volant Cool Air kit on my 5.4. The kit had me keep the mass air flow sensor and also a sensor that I believe measures the air temperature coming into the intake. I'm not sure how to close the circuit though, sorry.
Old Jun 21, 2004 | 08:32 PM
55FordLover
man thanks for the information....i wish there was somebody out there that can tell me if there is a cutoff relay adapter or something...the engine light is getting on my nerves!!!!!
Old Jun 22, 2004 | 12:18 AM
xallxforxchristx
hope my e-mail helped some. If you get a chance, take a look at the Volant Intake. I realize that you have already installed the other, but it might be worth it especially to get rid of the check engine light. That was one thing that kind of worried me when I went to start taking off the old intake, but another FTEr told me not to worry with the Volant because it fits perfectly, installs easily, and no check engine lights. I don't know how set you are on keeping the intake that you installed, but if you get a chance, you might take a look at the Volant, I feel that it would be well worth your time.
Old Jun 22, 2004 | 07:32 PM
triton_2002's Avatar
triton_2002
What year is your truck?
My 2002 5.4 F-150 has 3 sensors in the intake. The MAF sensor (just behind the air filter) and 2 sensors toward the middle of the intake tube: AIT (air intake temp) and ICS (idle control solenoid). The ICS isn't actually a sensor, its a vacum hose that goes to the sensor. You may have gotten the wrong intake for your truck if it doesn't have all the necessary conections.
Take a look at the Airraid website for instructions with pictures.
http://www.airraid.com/pdf/400-109.pdf
Old Jun 24, 2004 | 02:54 AM
drewcoolness99's Avatar
drewcoolness99
you could probably just jump the air temp sensor with a resistor, but I would not advise listening to anything I say, because its 3 in the morning and I have only had 5 hours sleep in the last 48 hours.
Old Jun 25, 2004 | 02:23 PM
94F150-408's Avatar
94F150-408
You do need to retain all of the sensors to have your engine run right and not get damaged. I would send back the intake you got and get one with the provisions for all of the nessasary engine control sensors.
james kelliher
Jul 28, 2015 05:42 PM
Ezalycasaid
Jul 16, 2015 05:15 PM
James.
Electrical Systems/Wiring
16
Jun 15, 2014 09:16 AM
Phantomfixr
1983 - 2012 Ranger & B-Series
24
Dec 14, 2005 08:26 AM
