1978 - 1996 Big Bronco
surge when idle
Old Jun 21, 2004 | 09:02 PM
emjc81402's Avatar
emjc81402
Angry surge when idle
To start I have a 90 351 w/ an e4od trans. When i bought it the exhuast had been dualled right after the o2 sensor removing the cat. I have a problem where the engine surges when idling, in all gear P,D,N etc..., if in reverse it will surge and die most of the time. when pushing gas no problem. I have read the threads where people have had a similar problems and replaced the plugs & wires, EGR valve, cleaned the o2 sensor. but before i start replacing much more i wanted to see if any one could help. Also when turning things on like a/c, lights, etc.. it makes it worse but I think thats due to the added strain to the engine. If anyone can help. thank you
Old Jun 21, 2004 | 09:13 PM
Cheap Monster's Avatar
Cheap Monster
Its the IAC. Take it off and clean it to the T with carb cleaner. Let us know if that helps.
Old Jun 21, 2004 | 09:15 PM
AYoungblood's Avatar
AYoungblood
Sounds like you have very little power.
Start by pulling your codes.
Goto search and type in pulling codes.
That should get you on a start.
Adam
Old Jun 22, 2004 | 01:14 AM
Superman_ManOfSteel's Avatar
Superman_ManOfSteel
maybe the TPS, that surging and variation in rpm's is a common symptom
Old Jun 22, 2004 | 06:55 AM
fcarruth's Avatar
fcarruth
Fuel regulator will do the same as will probably quiet a few other things but at least go tothe Zone and get your codes pulled for free. Or, like AYounngblood said, search and pull the codes yourself with a paper clip.
Good luck,
Old Jun 23, 2004 | 12:58 AM
Superman_ManOfSteel
id go with that
Old Jun 23, 2004 | 11:45 AM
emjc81402's Avatar
emjc81402
Thanks for the advice at least I have a little more direction and ill let you know what happens
