Differential leak
Old Jun 20, 2004 | 09:03 PM
Badfish1060's Avatar
Badfish1060
Differential leak
2000, 2wd, 115K, 6spd.
rear diff leaking, is much more pronounced after 30+ minutes of driving, but the whole thing always appears wet. When I first noticed it, I checked it and it too low to tell, but I got almost 2 quarts in it. I tightened all the bolts to the best of my ability (I got about a 1/4 turn on some of the lower bolts), but the problem continues.
I have never opened up a diff, but from what I have heard, I can pop that plate off and replace the gasket? Or is this problem bigger?
Thanks.
Old Jun 20, 2004 | 10:26 PM
johnsdiesel's Avatar
johnsdiesel
It's a simple fix. Take off the cover, completely drain the differential, clean the mating surfaces, use a gasket making product on one of the surfaces making sure to surround the bolt holes, and reinstall. Fill up with gear lube and friction modifier if you have limited slip. Shouldn't take more than 20 minutes.
Old Jun 20, 2004 | 11:27 PM
Kwikkordead's Avatar
Kwikkordead
Yeah it's easy. There is no gasket there, just silicone sealer. While it's off drill a little hole in the bottom of the bell and weld a nut to the inside. Install a bolt to the outside with a sealing washer and you have a drain plug for rear end oil changes.
Old Jun 21, 2004 | 10:07 AM
Badfish1060
Thanks guys, just the news I wanted to hear.
Old Jun 22, 2004 | 09:30 AM
Badfish1060
Ok, so I pulled the back plate, put the silicone sealer on, how long do I need to wait before, refilling/driving, etc.
The sealer said it dried in 1 hour, fully cured in 24 hours.
I was thinking I would refill it here in a little bit, but not drive until tomorrow.
Also, how can I tell if I have limited slip?
I didn't get any friction modifier?
Old Jun 22, 2004 | 10:51 AM
Craze's Avatar
Craze
Fish;
try this site:
http://www.drivetrain.com/Fordtrkratio_posidata.html
Old Jun 22, 2004 | 12:00 PM
Badfish1060
just filled it back up, they guy at autozone said I just needed to match the number m-5, and I would be fine, so that is what I did.
and using the speed sensor hole for a fill port is genius. Thanks for all the help.
