a/c problems
Old Jun 20, 2004 | 07:05 AM
dr worm's Avatar
dr worm
Question a/c problems
when i turn my a/c on max my 02 explorer the temprature guage starts to spike, i changed the thermastat and it still does it . does my system need to be charged?
Old Jun 20, 2004 | 07:56 AM
trike1946's Avatar
trike1946
Welcome to FTE. I assume you have two a/c settings. What happens on the lower setting? If that is cold, it probably does not need charging.When you engage the a/c you engine works harder creating a little more heat. But not enough to make a spike. I do not think a lack of charge will have any effect on engine temp. How is the compressor working? If it has a problem, it might be putting alot of drag on the engine. Are you sure the gauge is working right?
Old Jun 20, 2004 | 09:58 AM
dr worm's Avatar
dr worm
reply
ya the guage is ok, about a month or so ago i installed a perma cool electric fan when it gets hot like that i checked the fan for operation it was working fine,maybe it is the compresser i will look in to it thanks
mshargrave23
Sep 15, 2013 12:02 PM
cousinjc
Jun 25, 2010 01:28 AM
cousinjc
Jun 24, 2010 11:38 PM
bshackelford711
Sep 25, 2007 01:17 PM
