Engine pinging when cold
Old Nov 4, 2002 | 12:35 AM
kbarrett's Avatar
kbarrett
Post Engine pinging when cold
I have a 2000 XLT with the 4.0 SOHC V6. The engine sounds as though it is pinging when it is under moderate to hard acceleration when the engine is cold. If I speed up very slowly it will not ping. It only does this when it is cold. Most cars I have owned only did this once the engine reaches operating temperature. This one pings while cold and stops pinging once it reaches operating temp??? I have tried tightening the lower intake and I have cleaned the MAF twice. I did find a stuck thermostat this evening and replaced it, but when I drove into work this evening it started out pinging and continued to do so until the engine warmed up. I was in the process of taking a look at the ECT when I noticed that the truck had been running for almost 20 minutes and the upper radiator hose was ice cold. I then noticed that the anti-freeze in the radiator was also still cold. My best guess was that the ECT was probably getting bad information because there wasn't any anti-freeze flowing past it. It will probably take a day or two to see if I am on the right track. Also, where is the IAT sensor? Haynes says it should be just down stream from my MAF. It is not there, nor is there a fitting for one. That was going to be my next stop. Thanks in advance for any help you can give me.
Old Dec 4, 2002 | 11:59 AM
jgood's Avatar
jgood
My 99 x has the same problem with pinging when its cold, and I have never been able to found a solution yet. If you find the answer please let me know.
As for the IAT, I believe it's built in with MAF. That is where I found mine. You will need a special security star tool to access it.
Old Dec 4, 2002 | 03:31 PM
Opera House Works's Avatar
Opera House Works
tonyford
1983 - 2012 Ranger & B-Series
31
Nov 9, 2019 02:28 PM
fred_79f250
15
May 19, 2012 12:24 AM
bryes
Oct 3, 2011 04:54 AM
XLT2.5L
25
Aug 24, 2009 07:08 AM
Eric K
Modular V10 (6.8l)
126
Apr 20, 2008 12:35 AM
