Down Pipe 94 Td???
Old Jun 19, 2004 | 11:35 AM
94f2507.3td's Avatar
94f2507.3td
Unhappy Down Pipe 94 Td???
how do you remove downpipe on 94 f250 turbo 4x4? do i have to remove to r&r clutch??
Old Jun 19, 2004 | 04:06 PM
bilder12's Avatar
bilder12
If it is like the ones i installed, it is just a press fit into the turbo housing and can be removed by using a hammer on the bolt flange on the lower part of the downpipe. Wiggle tap, wiggle tap
Old Jun 19, 2004 | 10:23 PM
Hubble's Avatar
Hubble
you shouldn't have to remove it to r&r the clutch, but you will have to push the pipe out of the way to pull the trans. It would be easier to just pull the pipe since it's not too hard to take off once you take a good look @ it.
txgp17
15
Apr 26, 2011 07:50 AM
cmcowboy
Apr 2, 2009 07:23 PM
fishindave11
Nov 16, 2008 02:27 PM
Bowie
Nov 6, 2008 03:05 PM
