i have a microtuner and i have 35's on with 373 gears i dont tow anything just pulling tires i have pyro and boost gauges AFE magnum force air box and banks exhaust was wondering should i go with hi perf or perf tow or safe tow not sure what the diffference is. the speed limit what is that didnt know there was a limit on that.
You gear ratio is going to hurt you a bit on the EGT issue. You are going to pull the motor down pretty hard when starting off......because of the taller tires.
I might suggest going to this thread and reading as much as you can. There are a number of questions about tire size vs. gears and what it does to EGT's
i should have said its a 7.3 and that post is for a 6.0 i know about the gears im goin tto change in future i just want a idea what setting i should use
OOPS........it still is great reading
Watch you EGT's and try it, (the higher setting) you can always get off the throttle
