Sponsored by: Real Truck
1705 programer settings
Old Jun 19, 2004 | 07:26 AM
getnbz's Avatar
getnbz
i have a microtuner and i have 35's on with 373 gears i dont tow anything just pulling tires i have pyro and boost gauges AFE magnum force air box and banks exhaust was wondering should i go with hi perf or perf tow or safe tow not sure what the diffference is. the speed limit what is that didnt know there was a limit on that.
Old Jun 19, 2004 | 07:39 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
You gear ratio is going to hurt you a bit on the EGT issue. You are going to pull the motor down pretty hard when starting off......because of the taller tires.
I might suggest going to this thread and reading as much as you can. There are a number of questions about tire size vs. gears and what it does to EGT's
Her is the link for your reading pleasure, hope it helps.
https://www.ford-trucks.com/forums/s...d.php?t=234791
Old Jun 19, 2004 | 07:51 AM
getnbz's Avatar
getnbz
i should have said its a 7.3 and that post is for a 6.0 i know about the gears im goin tto change in future i just want a idea what setting i should use
Old Jun 19, 2004 | 08:12 AM
IB Tim's Avatar
IB Tim
OOPS........it still is great reading
Watch you EGT's and try it, (the higher setting) you can always get off the throttle
