Question for Gordo
Old Jun 19, 2004 | 06:08 AM
shaper's Avatar
shaper
Question for Gordo
Gordo, I have the same type emblem as your hookem horns,made out of the same material I think.Only mine is Texas flag. Should I wax this as normal and what about going thru a car wash.Is it durable enough?
Thanks
Old Jun 20, 2004 | 12:57 AM
GordoPanocho's Avatar
GordoPanocho
I got the following info from the .DOC link on http://www.zdecal.com/store/instruction.html:
Maintenance:
In colder climates, Decals on windows of vehicles can be damaged by the scraping of frost or ice from the windows. Mild window cleaner may be used to clean the windows without damage to the Decal.
On painted surfaces of vehicles, care must be taken when waxing. Wax will build up around the edges of the Decal, and will need to be removed. Use a soft cloth, and take your time, and be gentle. A brush, for example will force the wax underneath the edge of the Decal, and the Decal will begin to peel. The Decal will not be damaged by normal use of automotive car wash products, or water. Although the decals will withstand pressure washers, and automatic car washes, These will reduce the life and appearance of the Decal. The Decals will not last forever, but will give many years of service if taken care of.
Old Jun 20, 2004 | 06:52 AM
shaper's Avatar
shaper
Thanks Gordo.Thought wax would be a good way to protect them.Guess not.
Old Jun 20, 2004 | 08:58 PM
ultramax21's Avatar
ultramax21
When I wax my vehicles that have either pin stripes or "fx4" stickers on the rear panel I use a tooth pick to remove the wax from the edge of the stickers. Just take your time and it will look fine, then I use one of those "swiffer" dust rags that is supposed to be static charged which helps remove that little bit of wax dust. Hope this helps
Old Jun 21, 2004 | 01:12 AM
Toreador's Avatar
Toreador
It's strange to me. It would seem like covering the decal with a good wax would protect it longer. Does the wax "eat away" at the glue under the decal or something?
Old Jun 21, 2004 | 06:10 AM
F150Texan's Avatar
F150Texan
I use an old toothbrush...just my .02 worth
gordo 101
Kansas Chapter
May 14, 2006 10:56 PM
gordo 101
Kansas Chapter
20
Sep 16, 2005 01:29 PM
gordo351
Jan 12, 2005 05:37 PM
gordo351
Nov 24, 2004 06:28 PM
shaper
2004 - 2008 F150
Jul 6, 2004 02:25 PM
