Sponsored by: Auxito
No Break Lights!!!!!!! Help!!!!!!
Old Jun 18, 2004 | 10:43 PM
DeckedoutF150's Avatar
DeckedoutF150
I have a 2002 f150 and it came equiped with trailer tow package. well i recently bout a 97 f150 with a 5.4 and trailer tow so my 2002 is now jsut my show truck and it will no longer be used for towing or hauling. so today i decided to remove the factory trailer hitch and wiring for it. well after removing those parts i now have no break lights. i also checked the fuses and they are ok. i dont know what is wrong. if a wire was broke on one side that means that it would either blow a fuse or i would not have lights on one side. but i have no lights at all on either side. not even back up lights. anyone got any ideas??
Old Jun 19, 2004 | 08:12 AM
newfordy's Avatar
newfordy
Just an idea.....with a test light check to see if the connecter where you disconnected the "factory" harness has voltage with the signals on. Maybe the factory trailer harness "completes" the circuit for the truck tail lights. If so you may have to put it back. hope this helps
Old Jun 19, 2004 | 08:49 AM
DeckedoutF150
that what i was thinking. if i got to put it back on i am going to ahve to find a way to wire tie it to the inside of the frame so that it an not be seen. that thing is pretty ugly on the back of it.
Old Jun 20, 2004 | 12:42 AM
CanadianFordtech's Avatar
CanadianFordtech
Trailer lights have on the f150's have separate fuses from the truck lights, so you can have lights on truck and not on trailer working due to a blown fuse.
Old Jun 20, 2004 | 01:56 AM
DeckedoutF150
well i dont want the trailer wiring back on the truck cause i am not going to pull a trailer anymore with that truck. all i did was remove the wiring from the truck and now i ahve no lights
