Offroad & 4x4
Skyjacker or Procomp?
Old Jun 18, 2004 | 08:40 PM
roadster's Avatar
roadster
I am considering either a Skyjacker 6" or a Procomp 6 1/2" lift on my 04 SD Crew 6.0. I am going front and rear springs and Bilstein 5100's with which ever one I decide on. The problem is that the Procomp is $500 cheaper. Is the Skyjacker $500 better?
Old Jun 18, 2004 | 09:12 PM
freak98's Avatar
freak98
I would go with the Skyjacker.
Old Jun 19, 2004 | 07:11 AM
JeremyH's Avatar
JeremyH
Please do not buy pro comp.....their shocks suck, their springs are stiff and that line is sold at 4 wheel parts! That should be enough to turn anyone away.
Old Jun 19, 2004 | 01:44 PM
roadster's Avatar
roadster
Thanks for the replys. At this point I believe I will keep saving loose change for the Edge kit. It may be 2009 before I can afford it, but from what I've heard it will be worth it.
I was originally thinking of other lifts as I can afford them now and to go with the Bilsteins. I didn't realize there was as a dramatic difference in springs as there is.
Again, Thanks for the input.
Craig,
West Palm Beach, FL
Old Jun 20, 2004 | 05:26 AM
569104's Avatar
569104
I chose the Donahoe 4" spring lift for my 04 CC 6.0. It is worth the xtra money to me buy american. RCD is a little cheaper and their springs are made in USA also. If you don't care where the springs/lift are made, Superlift has virtually identical springs for even less $...(springs made in India or Canada) and they offer bilsteins. Also, with a 6" lift I would reccomend an adjustable trac-bar (pan hard bar). Good luck on whatever you choose.
Old Jun 20, 2004 | 06:20 PM
proeliator's Avatar
proeliator
Skyjacker makes good stuff. I wouldn't run any of the procomp stuff even if it was given to me for free.
Old Jun 21, 2004 | 04:58 PM
stealth1's Avatar
stealth1
I have the pro comp and it is really stiff. I upgraded my shocks to the 9000's instead of the 3000's and they are a little better than stock but not much. The lift is very tight and there are better lifts out there..
Old Jun 21, 2004 | 04:59 PM
fishmanndotcom's Avatar
fishmanndotcom
skyjacker has been building ford trucks for a longgg time! for a superduty I would go with something like a fabtech or BDS, I have heard real good things about them!
-cutts-
DL33R10US
Jul 2, 2023 05:12 PM
Bigdogca1966
Ford Truck Parts for Sale
Mar 10, 2017 07:53 AM
fordexception
Jun 3, 2015 10:59 PM
BIGTRUCKBIGRV
6.7L Power Stroke Diesel
May 13, 2015 05:03 PM
jsfx42007
Feb 22, 2009 01:49 PM
