Bleeding master and slave cylinders????
Old Jun 18, 2004 | 03:16 PM
94.5turbodiesel's Avatar
94.5turbodiesel
Question Bleeding master and slave cylinders????
How diffucult is it to bleed that master and slave cylineders. Its 1996 F-350 4x4. My buddy bought the parts to change his and we were wondering how much of a pain this really is? do we need a reverse bleeder system??? Any input would be graet, we value the suggestions on this forum.
Old Jun 19, 2004 | 08:21 PM
94.5turbodiesel
Come on. I know some knows how to do this, or can offer some insight, please.
Old Jun 19, 2004 | 10:19 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Does the 96 have an external slave like the Superduty?
Old Jun 19, 2004 | 11:44 PM
94.5turbodiesel
Yes, it is external.
Old Jun 21, 2004 | 12:54 PM
broke 350's Avatar
broke 350
why bother, mine failed and the fix was to replace it with an assembled bled complete system master slave lines and resivoir took 15 min
Old Jun 21, 2004 | 02:04 PM
94.5turbodiesel
Did you buy this from the dealer this way, already bled? Sweet deal.
Old Jun 21, 2004 | 08:37 PM
cookie88's Avatar
cookie88
FTE Emeritus
Getting all the air out can be a PITA, but if you detach the slave from the bellhousing and let it hang you can usually get it bled. If you do go the pre-bled route the part number for the assembly is 2c3z-7c522-ca. It runs around $125 local ($131.10 w/tax).
Old Jun 22, 2004 | 04:56 PM
broke 350's Avatar
broke 350
cookie88 is correct
