How to change coolant?
Old Mar 24, 2004 | 09:37 AM
JimmyG's Avatar
JimmyG
I am looking for advise on changing my coolant. Excuse my ignorance but I am looking for instructions or steps to take to do a good job. I have a 99 7.3 liter with 63k miles and have never changed the coolant and the recommeded interval is 60K. I have added the additive every 15K but thouoght I would change the fluid completely. I haven't even looked at the truck but I am wondering how do I drain the coolant from the radiator, resiovoir, and the block? What coolant should I use to repalce what I drain? thanks in advance.
Old Mar 25, 2004 | 07:28 AM
powerstroker250's Avatar
powerstroker250
Here you go https://www.ford-trucks.com/faq/1999...ce-Cooling.htm
Old Mar 25, 2004 | 08:17 AM
Birken Vogt's Avatar
Birken Vogt
I am not sure if it is necessary, but it seems to really speed up thermostat opening...I remove the temperature sender just to the left of the waterneck until the coolant reaches that level when refilling. Then I fill the radiator to the top. Then I fill the rest of the way. I run the engine briefly and then I crack the temp sender open again and more air will come out. Otherwise it seems like the water will take a long time to open the thermostat, and they don't provide any other bleed mechanism.
Birken
Old Mar 25, 2004 | 10:43 AM
JimmyG's Avatar
JimmyG
Ps 250, thanks for the link. Lots of good info.
Old Mar 25, 2004 | 10:49 AM
johnsdiesel's Avatar
johnsdiesel
How do you guys get rid of used coolant? It's a pain to get rid of it legally.
Old Mar 25, 2004 | 04:04 PM
wycowboy's Avatar
wycowboy
Make sure you do it right!!!!!, If my little sister's dog gets in to it and dies. I'll make clint eastwood look like wimp!!!! Remanber high plains drifter.... I thought so
Old Mar 25, 2004 | 06:34 PM
hodgekuter's Avatar
hodgekuter
It's great with Smirnoff or 151 Bacardi. Just kidding!!!
Bill in KY
Old Mar 25, 2004 | 09:03 PM
Stroker01's Avatar
Stroker01
Birken
I have always drilled an 1/8 in hole in the thermostat disk. This allows the air to excape when you are refilling. 1/8 isn't big enough to effect cooling/heating, but definately aids in air removal. This way you don't have to remove any other components or wait for thermostat to open.
Old Mar 26, 2004 | 07:39 AM
powerstroker250
Good tip that works well.
Old Mar 26, 2004 | 10:13 AM
Birken Vogt
There were recommendations specifically against drilling the thermostat in the early Ford diesels, and the Powerstroke has a hard enough time keeping itself warm. What is really annoying is they could have run another vent hose from the water pump to the surge tank, but didn't. Nor did they install an auto bleed like the IDIs. Oh, well.
Birken
Old Mar 27, 2004 | 07:34 AM
macrac's Avatar
macrac
I have a 01 PSD and after reading this thread I'm a bit confused about the coolant thing. Is their anything special I need to do with my coolant. I just purchased the truck back in December but nothing was said about testing coolant or adding an addative, am I missing something? I changed my oil yesterday and I noticed that my coolant level is close to the min mark so is there some special type of coolant I should use to fill it back up to the max? My truck has 56k so I'm definantley interested in hearing about this total coolant change at 60k. Any information on the testing and addatives would be greatly appreciated. This PSD maintenace thing gets addicting lol.
Old Mar 27, 2004 | 07:49 AM
Stroker01's Avatar
Stroker01
I changed mine over to Shell ELC so I dont have to use the additive. Even though its an extented life, I will still be changing it every 3 years. However, the whole key is to get it pre mixed at either 50/50 or 60/40 depending on the area you live. That way you dont dilute it with tap water that has the harmfull minerals. Shell dilutes it with Deionized water that is pure.
Hope this helps.
Old Mar 27, 2004 | 08:05 AM
powerstroker250
Go to the link I posted above.
Old Mar 29, 2004 | 03:42 PM
MADMAC's Avatar
MADMAC
I just went out and tested my coolant with the Fleetguard 3-way test strip. If my eyes aren't failing me, I get 2.8 or better. molybdate row 4 or a little better and nitrite columb F. Freeze point is at 60%. I believe that this is right on.
Old Jun 22, 2004 | 01:00 PM
onebuilder's Avatar
onebuilder
Hope this helps.
Good point here. Weather you get 50/50 or full strength, NEVER use tap water to mix with coolant in PSD's or any newer cars for that matter. Aluminum radiators don't like the chemicals in tap water. (And neither do water pumps). I find it it cheaper to get full strength and mix with distilled water (when adding 20 gallons of coolant, it works out to be about 70% of the cost of a 50/50 mix even after adding SCA's.
