Sponsored by: Real Truck
uh oh something is wrong?
Old Jun 18, 2004 | 02:49 PM
the deno's Avatar
the deno
ses light came on, went to autozone they said that the codes for both front o2 sensors faulted. anyone ever heard of two sensors all of a sudden just going like that? they are about 45.00 each a little too expensive to just start changing parts like that
Old Jun 18, 2004 | 02:53 PM
cwb's Avatar
cwb
Truck? Motor? Mods? I am assuming gas of some variety. Help us, help you.
Old Jun 19, 2004 | 09:08 PM
the deno's Avatar
the deno
oops!
f350,5.4-auto,k-n filter otherwise stock. 72000 mi.
Old Jun 19, 2004 | 10:31 PM
99f350sd's Avatar
99f350sd
Check the wires and stuff underneath...And no they don't go bad together.Sometimes they will last 150k...
Old Jun 19, 2004 | 10:56 PM
the deno's Avatar
the deno
forgive for beig a little stupid,but are you refering to the plugs on the o2 sensor itself?
Old Jun 20, 2004 | 10:05 AM
99f350sd's Avatar
99f350sd
Sometimes a wire can get cut or a connector can fall apart...In other words do a complete visual to make sure nothing simple hasn't happened.. first...
Old Jun 20, 2004 | 05:45 PM
the deno's Avatar
the deno
thanks for your info,broke down and bought the same scanner autozone uses,figure it couldent hurt,probably going to need it anyhow. i got the same codes they got, going to check all the connections,wires,etc.then see what i get. again thanks for the help..deno
Old Jun 24, 2004 | 08:49 PM
the deno's Avatar
the deno
just wanted to say thanks for the help again! it was the plugs on the o2 sensors,unplugged and plugged them back in,no more codes checked, everytime ive driven the truck. thanks again
Old Jun 24, 2004 | 09:31 PM
99f350sd's Avatar
99f350sd
Super.........................................
Old Jul 11, 2004 | 02:38 AM
shapel's Avatar
shapel
instead of replacing the o2 sensors why not just pull them out out and clean them and put them back in? hmmmmm?
