Sponsored by: Auxito
Parking brake sticking
Old Jun 18, 2004 | 08:12 AM
falcon5's Avatar
falcon5
I have a 2001 F150 SC and have had continueous problems with the parking brake getting stuck on. I have had the brake cable replaced by the local dealer and after that it worked fine for a while.
Since I do not use it very often, it is difficult to gauge when it stopped working again, but if I use it now, it will remain engaged on the rear passenger side until I get under and tap the brake arm towards the rear of the truck to release it.
What can I do to check this out and fix?
Old Jun 18, 2004 | 10:50 AM
mikeB1's Avatar
mikeB1
I have a 2000 F150SC 4WD I pulled the rear discdrums off disassembled all the park brake parts and applied never seize to all moving parts including the actuator arm. That has done the trick so far one and one half years.
Old Jun 18, 2004 | 07:46 PM
RCOAPSTICK's Avatar
RCOAPSTICK
there is no woay to fix it. dont worry about replacing the cables anymore. The problem is that u do not use it that often. if you are going to use it you should use it everytime you park, but really since u dont need to use it{that is unless ur transmission is manual}, i would recomend not using it. If it isnt used alot it will stick, so there is no probleme really. hope this helps you.
Old Jun 19, 2004 | 10:58 PM
hood's Avatar
hood
My 02 F150 (40,000 miles) had a similar problem with the parking brake. Except i use my parking brake ALL the time since day one of owning the vehicle.
My parking brake light would stay on until i played with the release handle. It wasn't until the brake actually hung up and started to heat up to the point of smelling it that i went to the dealer to complain about it. They found that the mechanism/cable had rusted/corroded up and prevented it from releasing fully.
My extended warranty covered the service repair which was cleaning and lubing the cable except for a $20 charge for BS they managed to say they needed to charge me for.
Anyway, now it seems that i need to press the parking brake pedal all the way to the floor for it to engage. I may be going back again because i'm not very happy about the way it works now.
-hooD
Old Jun 20, 2004 | 07:25 PM
falcon5's Avatar
falcon5
Cool
Thanks,
I have just replaced the front pads and will be going in to check/replace the rear next weekend. I'll disassemble the drums and check for any siezed parts when I'm in there.
Luckily, the cables were replaced under warranty last year - you'ld think the dealer would check the rest of the mechanism when they did that...
Thanks again
300sflyer
Nov 7, 2014 10:29 PM
usafstud
1997 - 2003 F150
Dec 1, 2011 10:36 PM
bkvanbek
Aug 12, 2011 09:13 PM
Rusty_Old_F250
Apr 21, 2011 11:11 PM
2010Raptor
Large Truck
Aug 26, 2010 08:47 AM
