95 explorer with the shakes!!!
Old Jun 18, 2004 | 07:20 AM
metalgear138's Avatar
metalgear138
i own a 95 explorer sport with almost 160k. bottom line is that it shakes and vibrates REALLY bad..but only when im going above 65mph. ive read that it has something to do with the rear susp. but not too sure as to what triggers the bad vibrations when im going fast..if anyone else has had expierence with this annoying problem and has solved it..please let me know how you did it!!! thanks.
Old Jun 18, 2004 | 02:14 PM
mrshorty's Avatar
mrshorty
First thing I'd check is proper tire balance.
Old Jun 18, 2004 | 03:26 PM
GrayRanger4x4's Avatar
GrayRanger4x4
^^ do first,If its not your tires /rims> Then check your U joints .With the short drive shafts on your X they will shake worse if they are going bag.If its a 4x4 check all the u joints.
