Computer Chips & Tuners
1715 Tuner-Code Reading.
Old Jun 18, 2004 | 04:44 AM
alarsso4's Avatar
alarsso4
96-150 5.8.
I have checked the base timing, whith spout conn. disconnected and motor idling. When this is done, I get code 1359, which is as it should. After I erase this code, I get code 1000 " OBD II Monitor Testing Incomplete", and I can't get it away. Isn't the tuner able to complete the job, or is it the owner(me)? I'll appreciate some help.
Old Jun 18, 2004 | 06:57 AM
ssn randy's Avatar
ssn randy
code 1000 is telling you that enough time has not elasped since you erased codes. drive around, it needs time to run all the tests required by the program. normally a couple of key cycles and some driving time. it will clear itself when all the tests it requires for the diagnostics of the ODB II system are completed. you can't erase it.
Randy
Old Jun 18, 2004 | 10:22 AM
alarsso444's Avatar
alarsso444
ssn Randy:
Thank You! I don't have to worry about that.
akblackfoot
Nov 10, 2017 08:44 AM
tomstoner06
6.7L Power Stroke Diesel
32
Jan 19, 2014 03:11 PM
wadestreet
49
Feb 10, 2012 03:31 PM
