1946 ford pkup bed
Old Jun 17, 2004 | 08:14 PM
jim46ford's Avatar
jim46ford
1946 ford pkup bed
Just purchased a 1946 ford the cab and flathead v8 are in good condition.
Need some ideas the bed to keep it loking good. Is ther another model that fits well??? Also looking for an Alternator bracket!
Old Jun 20, 2004 | 08:02 PM
41Clay's Avatar
41Clay
Welcome to FTE! And congradulations on the purchase of your new family member.
The beds from '40-47 should be the same as yours. There are 1 or 2 guys here who have or at least thought about using the beds from '48-'52 which are the same size but use a differnt more square fenders simular to the fronts ('51 went to flat sides). They don't mount the same way but shouldn't be that hard to get them on. As far as I know the '53-'7? are the same dimintions as the '51-'52 flatsided but the fenders have a different bolt pattern, in '57 the fenders stayed the same style but were moved a few inches lower on the side of the bed.
Would love to here more about the condition of the truck and maybe see some picture. Good luck!
Old Jun 21, 2004 | 03:44 AM
j wright's Avatar
j wright
Welcime to FTE and to the 47 and Older forum!!!! If you are looking to keep it stock looking new beds are available. I have found this site very friendly and really helpful so any questions you have feel free to ask and I'm sure that lots of people will help. Again welcome!!!!!!!!!!!
John
Old Jun 22, 2004 | 01:34 PM
46fordtruck's Avatar
46fordtruck
The beds from a '40-'41 are not the same, in '42 Ford went to a wider bed, so it looks they look the same, but they are different. '42-'mid '50 are the same, except in '48 the fender bolt pattern is different for the rear fenders. I have a '51 bed on one of my '46's that I am building, and it does bolt right to the frame, but it is flatsided, so the fenders are different. Also note that the '42-'47's are the only ones with the spare tire carrier welded to the side of the bed, if you wanted stock, you'd have to add one to a later bed. Alt brackets for the flathead 8 are easy to find, check out a speed shop, like http://www.speedwaymotors.com for one, they also have all the other info you need to make the alt conversion go easily.
Old Jun 23, 2004 | 12:36 PM
John W Cina's Avatar
John W Cina
Beds 47
Complete beds are available from Mack Hils in MO. who also wrote a nice book on early fords.
We were just at "Back to the Fifties" with our very orginal 47 1/2ton 54k miles pickup---lots of fun enjoyed all the comments on our orginal farm truck.
John
Old Jun 28, 2004 | 07:12 PM
jim46ford's Avatar
jim46ford
hi. I havebeenoutoftouchIhavesomenumbersI'vedfoundneedso mehelptoidentifytheengineno.is699y-996120 themodelno.69-y Ienjoyreadingyou-allletters
Old Jun 29, 2004 | 12:12 PM
46fordtruck
The numbers you give show a 1946 V8 1 ton truck. The 1 tons used a longer & wider bed than the 1/2 tons, and I don't think anybody is currently making a 1 ton replacement bed. The interchange should still be the same as stated in previous posts.
Old Jul 6, 2004 | 06:21 PM
jim46ford's Avatar
jim46ford
Hello my friends you all have been some good help. I would like to know what a bed would run for this 1946 ford 1 ton pick up truck or do they make them.
Old Jul 7, 2004 | 12:00 PM
46fordtruck
Don't think I've ever seen a 1 ton bed reproduced, usually just the 1/2 tons. You could always put a stake body on it, Northern Classic trucks makes a stake bed kit, should work on the 122" WB 1 ton frame. But if you really want to keep the pickup bed, then you'll have to find a good used bed. I've seen whole 1 ton trucks with decent sheetmetal go for decent prices on eBay...might look into that.
Old Jul 9, 2004 | 08:34 PM
jim46ford's Avatar
jim46ford
I have a 1987 ford ranger front suppention will it bolt up to my 1946 1 ton front end it got the late model suppention I belive twinn I beem I think please help me and I would thank you all.
Old Aug 16, 2004 | 08:06 PM
jim46ford's Avatar
jim46ford
Smile
do any one know if they make a fiberglass tilt hood for a 1946 ford pickup if so do you know the web site thank you jim46 ford
Old Feb 11, 2023 | 08:29 PM
Ja1702's Avatar
Ja1702
1st Gear
A new project. I just bought a 1946 ford pickup
It has no bed on it any suggestions? It is hard to find original parts for this truck!
Old Feb 11, 2023 | 09:24 PM
51504BAT's Avatar
51504BAT
https://mack-products.com/shop/produ...sembled-stock/
Old Feb 12, 2023 | 07:07 AM
truckdog62563's Avatar
truckdog62563
Marmon-Herrington Man
Old thread. If the new member has a one ton the same guidance applies as before. None are being repop’d. The more common 48-52 Express 8’ beds are the same and can be used, but fender studs would need to be moved to the earlier locations if early style fenders can be found. I got lucky and found a nice original bed and acceptable fenders for my 47. Stu
1952henry
1947 and Older Ford Trucks
28
Jun 10, 2020 12:02 PM
sdjaur
May 29, 2016 07:35 PM
christurney77
Sep 28, 2015 03:24 PM
geetoe
Dec 28, 2010 10:26 PM
jdhudall
20
Mar 21, 2010 10:08 PM
