c94 injectors
Old Jun 17, 2004 | 07:13 PM
catrepair's Avatar
catrepair
c94 injectors
Ive got an 01/o1/03 truck ,I see alot of posts about the c94 injectors, are the problems mechanical or electrical,by the time I smell fuel in the oil, Ive allready washed the bearings. What was the symptom,before the dealer sighted the injectors as the problem.
Old Jun 17, 2004 | 07:34 PM
jschira's Avatar
jschira
The C94s are prone to side loading on the plungers, which causes the plungers to scuff up and leak.
A rising oil level is the best way to check for fuel in oil. If you catch it early, you should be OK.
Old Jun 17, 2004 | 09:03 PM
jdadamsjr's Avatar
jdadamsjr
I have 29K on my 6.0 and am pretty sure I have the c94's, but have not had any issues with them....
I have a 100K extended warranty and you have at least a 100k engine warranty, so the way I look at it, if it fails I get me another engine !
Old Jun 17, 2004 | 09:08 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
My 03/03 has c94's and I keep an eye on the level................they are more sensitve to higher oil level in the pan.
Old Jun 18, 2004 | 05:18 PM
catrepair's Avatar
catrepair
ok tim,now you got me scratching my head, sump oil level, relates to injectors in what way?
Old Jun 18, 2004 | 06:49 PM
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
The second generation rail type injectors on the 6.0 liter uses engine oil powered by a high pressure oil pump to fire the injectors.
Old Jun 18, 2004 | 09:54 PM
IB Tim's Avatar
IB Tim
To high of oil level will foam.......the injectors need oil not foam.
Foam is tuff to pump and maintain PSI
Old Jun 19, 2004 | 08:47 AM
Hjudge49's Avatar
Hjudge49
And when the injectors leak, the excess fuel runs past the piston rings, dilutes the oil, and bad things happen. I check the oil leel at least every fill-up, and often in between. If it rises, or I smell diesel fuel on the dipstick, I know there's a probelm. 01/03 engine, 32,000 miles so far no injector failures, but I'm still testing every oil change.
Old Jun 20, 2004 | 08:02 PM
SBV45's Avatar
SBV45
I also have the C94 injectors. 18,000 miles plus and running good.
Old Jun 20, 2004 | 08:48 PM
dpoelstra's Avatar
dpoelstra
25,000 on my C-94s with no problems. It seems that the guys who have problems with them have the problem very early. Has anyone had problems after 20,000 or so?
Old Jun 20, 2004 | 09:21 PM
IB Tim's Avatar
IB Tim
I think that is a very importatn point
Old Jun 21, 2004 | 06:09 AM
SBV45's Avatar
SBV45
I am going to do my next oil change at 20,000 and send in an oil sample to Blackstone.
Old Jun 21, 2004 | 09:02 AM
"Luke" SdeS's Avatar
"Luke" SdeS
Fm Tim
Therefore, with the above in mind; when taking your truck in for maintenance, should you want to allow a dealer to do the work, remember to insure that the comments noted below, be placed on the work order......
Not withstanding anything to the contrary contained herein,
I do not authorize any flashing/reflashing of any of this
Truck's computers; This prohibition is of the essence.
Just A Thought...............on...............My Perceptions................
Old Jun 21, 2004 | 10:49 AM
dpoelstra's Avatar
dpoelstra
I was not aware that the reflash had anything to do with the C-94 injectors going bad.
I bought my truck in 5/03, with a 3/03 engine build date. The dealer immediately replaced the PCM and reflashed under a recall, and the tech said that they thought this was part of the injector problem fix.
Any feedback on this?
Old Jun 21, 2004 | 10:55 AM
Hjudge49's Avatar
Hjudge49
I had that same flash, It was before I knew better. That one takes away the Pilot Injection, but I don't think it does squat for curing the problem with the c94's. Their problem is mechanical, the design of the shoulder of the injector makes it succeptible to wear and binding. If you look at a cutaway of the c94 and c95 side to side you can see the difference. I hope the theory that they fail early is right and that I'm past the danger......but I'm still checking the oil.
