Oil Pan leak
Old Jun 17, 2004 | 04:56 PM
Icicle's Avatar
Icicle
Oil Pan leak
Anyone have any NON mickey mouse ideas for an oil pressure line that is leaking where prev owner tapped into the oil pan? on 79 400 in a bronco?
Old Jun 17, 2004 | 05:13 PM
Kynetx's Avatar
Kynetx
Try cleaning the area and applying silicone, unless you consider that to be Mickey Mouse.
Old Jun 17, 2004 | 06:59 PM
dimora's Avatar
dimora
Yeah...Here are a couple of options.
1) Drain the oil, pull the pan clean it to bare metal, and weld it. I bet any muffler shop (or any mechanic with a welder) would charge you under $20 to zap it. You can then grind it down yourself and repaint.
2)Drain the oil, pull the pan, drill and tap a hole that is bigger than the current hole, tap and thread a bolt into it, with some silicone so it doesn't leak.
You can buy a chrome oil pan on Ebay for under $40.00...or check Summit Racing or Jegs and just get a new one.
If you want to go Mickey Mouse style, try some JB Weld.
Regards,
DiMora
Old Jun 18, 2004 | 09:51 PM
mark a.'s Avatar
mark a.
I'd probably just drain the oil, clean it with brake clean, & braze it without removing it.
