Hallo I here again
In my Explorer when I'm start the engine (cold engine) the rpm's going up und down about 1 min. after then the rpms goes normally.
Second thing is very often when I after cold or rainy night i start the engine and start to driving (5 - 10 min) goes on the check engine light so I must reset the engine computer. My engine is after tunning and the way to computer managment system is changed so no one from Poland service station can go and read the bug-codes
So that car goes wonderfull and take about 11-15 liters fuel on 100km,his take no oil...I dont know what its the reason of that trouble.. Please help me
Welcome, my Polish breathren. Wondoloski is my name. I don't know one bit of Polish. It pretty much died off with my great-grandmother.
The rpm's going up down is a pretty common problem with Explorers. If yours runs normally when warm, I don't think it should be a problem.
I have had a similar problem with the check engine light going on when it rains in about 3 different cars I have owned. They all turned out to have the same problem: bad oxygen sensor. Once it was replaced, all 3 cars returned to normal.
[updated:LAST EDITED ON 15-Dec-02 AT 05:02 AM (EST)]Hallo
I'm suppose in New York is ZIMNO but in My city is now -15 Celcius grads .... what do You think about it.....
I waiting for Your support.....thanx
Greetings from Poland
[updated:LAST EDITED ON 15-Dec-02 AT 05:03 AM (EST)]Hallo Mr.Wondolski
Could You tell me where is the oxygen sensor??? I have no idea
and one more thing my speedometer when I drive very fast 140-150 km/h
(its about 60-70 mph) going down, I was replaced the speed sensor but the problem is still there.....
It appears that you either have a '97 or '98 Explorer. If your Explorer has the 4.0L SOHC V6, then this is a commons sign of leaking lower intake manifold o-rings. Here in the U.S.A. Ford extended the warranty to 6 years, 72K miles through Owner Notification Program 00M12. I know some European countries will honor it as well. Have your local Ford dealer get in touch with Ford USA and ask about ONP 00M12. It's possible that you might get it fixed at no charge.
[updated:LAST EDITED ON 18-Dec-02 AT 02:48 AM (EST)]Hallo
Thanks ...Ok I try to check it...
BUT CAN SOMOEONE TELLING ME WHERE ARE THAT OXYGEN SENSORS in my car ??????????? I was ask in authorised FORD dealer they don't know... It's not strange ITS POLAND !!!!!!!
Your O2 sensors are on your exhaust pipes. You have one on the pipe between the exhaust manifold and the catalytic converter for each side. Depending on your engine you will also have one or two more on the pipe(s) between the catalytic converter and the muffler. If you have the OHV 4.0L then you have one after the cat, if you have the SOHC or V8 then you have two after tha cats. They are not in the catalytic converter. Look for a small electrical device that is mounted to your exhaust pipes between your engine and your muffler. Each one has a wire harness going to it.
