Aerostar Ford Aerostar
Front End Alignment
Old Jun 17, 2004 | 10:56 AM
DURSO's Avatar
DURSO
Question Front End Alignment
Had a front end alignment done at the Valencia Ford dealer yesterday on my 92 Aerostar EXT AWD Eddie Bauer.
Car is tracking very straight now with my hands off the wheel, but the steering wheel is slightly turned to the right.
Do I need to be concerned that the steering wheel isnt straight, even though the car is tracking straight?
Thanks - Tony
Old Jun 17, 2004 | 02:40 PM
aerocolorado's Avatar
aerocolorado
Ford states a deviation of +/- 5 degrees off center is acceptable. If it is any consolation, my '91 AWD is always slightly off center as well. You may notice when the tires are rotated the wheel may come back to proper center, then be off again at the next rotation. I have had my front end aligned at least 15 times over the years with the same results. It still drives me nuts but I've learned to live with it.
Old Jun 17, 2004 | 03:14 PM
DURSO's Avatar
DURSO
Thanks Aerocolorado! I will live with it...But yes, it does drive me nuts
Old Jun 17, 2004 | 03:44 PM
copper_90680's Avatar
copper_90680
Hypochondriac Aerostar?
Old Jun 17, 2004 | 05:05 PM
aerocolorado
And one that makes a pathological liar out of my wife ----- "that van is (fill in the blank problem) but as soon as I drive it, no problem is found. Sexist Aerostar?
Old Jun 17, 2004 | 07:43 PM
eehoepp's Avatar
eehoepp
I replaced the tie rod ends on my van a year ago and I was surprised that there are no adjusting sleeves for the rod ends. Basically, the toe-in adjustment is made in one-thread increments of the tie rod ends into the rack. There is almost zero chance of getting the steering wheel centered and the toe-in set properly at the same time. So the steering wheel is always slightly off-center.
But then again, I've been described as slightly off-center more times than I care to recall...
Cheers,
Eric
Davidjoe
Large Truck
Jan 7, 2016 11:31 PM
cajun_driller
6.7L Power Stroke Diesel
Mar 16, 2014 07:30 PM
OleGrouch
Aug 17, 2012 10:37 PM
cbzdel
Jun 20, 2012 10:24 PM
davidsheets
Jan 29, 2010 11:55 AM
