4.0 comp cam
Old Jun 17, 2004 | 10:35 AM
PRSplaya's Avatar
PRSplaya
4.0 comp cam
Anybody ever put a comp cam in a 4.0 ranger/B4000? What gains can be expected and how much trouble is it?
Old Jun 18, 2004 | 01:06 AM
mako5972's Avatar
mako5972
Comp Cams offer 2 cams for the 4.0. One is a stock replacement being good for torque and mileage. Operating range is 800 rpm to 4800 rpm's duration @50 intake 200 exhaust 210 lift w/1.5 rocker intake .465 exhaust .500 the part number is 49-410-8. The grind number is 256HR. The other cam is good in Explorers and Rangers with an aftermarket chip. It has strong torque and mid range. The operating range is 1200 to 5200 rpm's. The part number is 49-422-8. The grind number is 270HR. The duration @50 intake 215 exhaust 224. The lift w/1.5 rocker intake .500 exhaust .500. Both of these cams are their High Energy cams.
I have not done any mods to a Ranger or the B4000. I can't tell you how much more power you would expect. Call Comp Cams CAM HELP line at 1-800-999-0853.
Good luck.
Old Jun 18, 2004 | 07:16 AM
PRSplaya's Avatar
PRSplaya
Thanks. My truck will mostly be used for off-roading. Right now all I've done is add an open air intake and a gibson cat back. I also plan to add a diablo delta chip, but I want to get the cam first so the chip can be programmed right. Unfortunately, most of those numbers you gave mean nothing to me, since I don't know too much about cams. Which do you think would be better for my purposes. Oh, and I'm also thinking of changing the gears out from the 3.73's to some 4.10's or 4.30's (33x12.50x15 tires).
Old Jun 19, 2004 | 08:41 AM
mako5972's Avatar
mako5972
Call the Cam Help Line at 1-800-999-0853 they will help you pick the right cam for your installation. They are knowledgeable and friendly and the call is toll free. As to the breakdown of the cams I listed: 1) stock replacement 2) performance above stock.
When you pick a cam you must select the right one that conforms to your driving habits. However all of the High Energy line of cams are streetable. The Cam Help line will even help you with which gears for your differential to match it to your cam.
timmyo302
Feb 2, 2015 03:54 AM
Tonkatoy77
Jun 8, 2014 11:16 PM
court1100f
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Oct 3, 2013 07:37 PM
dlk
Modular V10 (6.8l)
Oct 1, 2008 04:48 AM
PMDRACER
Modular V10 (6.8l)
22
Feb 4, 2007 05:24 PM
