its mainly done for close valve to piston clearances in a higher compression race engine or people runnig big shots of nitrous. you may not get much benifit on a daily driver.
maybe a true race engine builder here can elaborate on this.
no. that I wouldn't know much of so you can understand my confusion.
I was on the line of orienting the opening of the plug for the purpose of clearance or for controling the burn of the mixture from the quench area by usaully setting the plug to face the exhaust valve.
like to know more about the firing order change but I don't think thats the heart of the question. but maybe, Brian?
Well sorry about that...the plug indexing to the face of the valve Im not firmiliar with?
There is a set-up tho that some of the Heavy Hitters use..they have a cam ground to change the firing order of 2 cylinders..to make a slightly less load on the lower end..
was what I was thinking you meant..LOL!! Have a good day. Russ
You orient the plugs so the gap faces the intake valve. It's supposedly worth a couple of HP. I do it on the racecar; it's not worth the time or effort to do it on the street.
When you index the plugs on a race engine you are trying to orient the ground strap as far away from the piston as possible to avoid contact on high compression engines with domed pistons.
>Last night when reading thru some old hotrod mags i have, i came across
>an ad for sized washers that you put on your spark plugs to assure the
>plug gap is facing the proper direction for maximum burn of the air-fuel
>mixture. Does anyone out there know if this really helps performance and
>if so how much??
The purpose of indexing plugs is to a) place the ground electrode where it
will cause the least disturbance to flow and b) where there will be
maximum exposure to the mixture flow at the instant of ignition.
The direction of mixture flow is variable and may even change with RPM
and tuned header/intake action.
Like a lot of other things you can do, indexing the plugs may or may
not help your particular engine. The only way you can discover
whether it helps or not is to try it and carefully record the results.
Note that extensive testing may be required because the proper direction -
if any - of the ground electrode must also be determined experimentally.
This is absolutely not a "bolt'n'pray" type of tuning tool.
Yes I was reffering to the orientation of spark plugs.
So which way should they point I have the indexing washers. My head man told I should index them for a few more horses but, I thought he said to point the opening at the exhaust valve. There are no clearance issues in this motor.
What rapidruss is refering to is the same reason a 302 firing order is different than a 302HO and a 351W. A stock 302 fires 4 and 8 (if I remember right) in sequence in the order which they say causes heavy load on the rear main bearing.
I have also heard that when indexing your plugs, have the opening face the intake valve. It's only good for a few HP, and I doubt you will feel a difference.
I've never heard anything about it being due to piston clearance to the electrode.
I have personally never tried it, but I have seen other drag racers that in effect cut the ground electrode off. They leave just a nub at the side of the plug. If you have the ignition system to jump it, it throws a heck of a long spark.
Not saying that drag racers don't do it, but that is a good way to burn a hole in the top of your pistons. I have seen it happen.
I can assure you indexing works. The jap's call out a spec for their modern outboard engines. Why? For the two reasons above, flow and flame front. I expect flame front is about 90% of the reason. With precise engine controls and sensors, they are getting every last molocule they can to burn at exactly the right time to squeeze everything out of the fuel and the engine is so sensitive to variation that the plug orientation will upset the system. If you do not have the sensors (like a G-tech) and a digitally controlled engine, indexing has got to be a lot of hours invested for little or no return. So....
Brian, I see how removing the ground electrode is a bit radical but I don't understand why it is linked to burning holes in pistons. Please explain. Thanks
