P0174 & P0171
Old Jun 16, 2004 | 11:12 PM
Davez99Expy's Avatar
Davez99Expy
P0174 & P0171
I need help!!! All I can figure out from my manual is that both bank 1&2 are running lean. But why??? I changed both O2 sensors (does that control Air Fuel mixture?) no change.
I added a K&N air filter about 4 months ago. could that be letting in too much air??? Strange that code only popped up just a few days ago though.
I'm new to this forum, thanks for any help.
Dave
Old Jun 16, 2004 | 11:35 PM
Davez99Expy
P0174 & P0171
forgot to mention: 99 Expy, 5.4L, 96k miles
Old Jun 17, 2004 | 04:35 AM
brooks35's Avatar
brooks35
It is probably the vacum line that runs to the rear of your intake manifold from the pcv valve. they tend to crack and leak tripping the lean code.Mine did the same thing.Hope this helps fix it.
Old Jun 17, 2004 | 04:53 AM
trike1946's Avatar
trike1946
Yeah, check the vacuum lines. I have a K&N with no problem. If no vacuum leaks, take it out for a good run, then cancel the codes and see if they return.
Old Jun 17, 2004 | 11:52 AM
bodu's Avatar
bodu
I had the same problem and it was the PCV elbow at the rear of the manifold. It fell apart as soon as I touched it. I replaced it with a Chrysler one from Autozone that cost under $2. Hard to get to, but a cheap fix.
Old Jun 17, 2004 | 03:26 PM
Racerpro's Avatar
Racerpro
P0171 / P0174
I had the same error codes and finally took it to Ford of Tulsa 2 days ago. It was repaired at a cost of $236.16. They replaced the PCV hose, They said it had developed a hairline crack in the hose where it connects in the back of the engine and would only fail under acceleration. I also had replaced the high dollar O2 sensors just to have the errors return. Error has not returned since repair. Hope this helps.
Ken
Old Jun 17, 2004 | 09:52 PM
Davez99Expy
I'll follow up
thanks for all your input. I'll replace the PCV hose on Sunday and post reply on how it turns out for me.
I appreciate the help!!!
Dave
Old Jun 21, 2004 | 12:52 PM
Davez99Expy
P0174 & P0171
Fixed!!!!!
It was the vacuum line (actually the rubber elbow) that had a little hole in it. the guy at Napa gave me a 4" piece of hose free of charge!!!
thanks for the help!
Dave
