Bronco II Ford Bronco II
2.9L power mods
Old Jun 16, 2004 | 09:20 PM
'88Bronc's Avatar
'88Bronc
2.9L power mods
Hey guys,
I have a '88 Bronco II (duh right) 4x4 with the 2.9L and auto on the floor. I'm looking to get more power out of the old girl, in the form of headers, dual pipes, ignition, intake manifold, etc. Does anyone know of a good company/website for performace parts for my motor? Any tips on this project are appreciated.
Thanks
Old Jun 16, 2004 | 10:44 PM
Aggie05's Avatar
Aggie05
IM not sure how it works but i know there is a power chip at auto zone you can order, its manufactured by hypertech, if you decide to get it plz post the results and let me know if its any good, last time i checked it went for almost 200$. (does anybody know if those things work)???
gl with the power mods
Old Jun 17, 2004 | 10:01 AM
Ken00's Avatar
Ken00
JBA makes headers for the 2.9 I believe, check out Gibson, Borla and Flowmaster for exhausts. You can port and polish the intake, check this out. And our parts shop, motorhaven.com has good chips.
Old Jun 17, 2004 | 10:49 AM
GrayRanger4x4's Avatar
GrayRanger4x4
Heres a easy bolt on mod.Find a 86/87 2.9 and get the 58mm TB off it, bolts right up,you have to use you TPS.Be real carful and you can use the old gaskets.Its not a kick in pants mod but you get a little more botton grunt.
As far as the ignition goes the stock one will be good enought for the HP you will get out of a 2.9,Just get a good cap and some 8.8 wires and autocraft platium plugs,you'll have all the fire you'll need.
Old Jun 17, 2004 | 05:50 PM
'88Bronc's Avatar
'88Bronc
Thanks,
and i was also thinking about getting a power chip from James Duff, does anyone know anything about this chip? It is suppose to make 30 extra hp on a 4.0L, but it doesnt say for the 2.9L.
Old Jun 17, 2004 | 07:01 PM
Ken00's Avatar
Ken00
You should also ask about the chips at our chip forum, they should be able to give you some more insight.
Old Jun 18, 2004 | 09:06 AM
TimMcGraw67's Avatar
TimMcGraw67
Chipping the car is basically (usually) piggybacking a chip that has been reprogrammed to quicken shifts (with AT that computer controlled) Also it has the capability to be programmed to open or close the injectors faster or slower, basically override the PCM's factory programming, tuned for performance.
Old Jun 19, 2004 | 08:15 PM
'88Bronc's Avatar
'88Bronc
After a little more talking around, i think i'm gonna get the chip from James Duff. Aside from that, i heard Edelbrock makes an intake manifold for the 2.9L. If so, where could i get one, directly from Edelbrock?
Kadin Cook
1983 - 2012 Ranger & B-Series
Mar 20, 2017 03:21 PM
wagonerkl
Bronco II
22
Mar 6, 2009 05:19 PM
blackcrow_75
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Aug 11, 2007 03:15 PM
88stxRanger
Mar 8, 2007 11:14 PM
The Phenom
Feb 26, 2005 12:22 PM
