What does a cam position sensor do?
Old Jun 16, 2004 | 05:10 PM
Diesel Daddy's Avatar
Diesel Daddy
I've been reading about the Cam Position Sensor. Does it effect performance, like some hesitation, etc? My truck stalled a couple of times one day, once at a stop light and then about 4 miles down the road @ 55 mph! Well, it's been about two or three weeks and it hasn't happened since! But, I do notice some hesitation on acceleration from a roll... Any ideas? Its a 1997 F350 Crew PSD w/114k miles on it.
I really noticed the hesitation after I visited the Ford dealership when they changed the oil and fuel filter (they pressure tested the fuel system too). These maintenence items were done BEFORE the day it stalled.
Thanks
Steve
Old Jun 16, 2004 | 07:50 PM
bobcatv8's Avatar
bobcatv8
Take it to a shop that has a scanner to check the codes and/or check the whole system out. From what I've seen, when a cam sensor goes out you will be down until it's fixed. It will let you drive in a "limp home mode" but I don't think it will fix itself. At 114,000 miles it's not uncommom to have one go out. Anyone else have any more experience with this?
Old Jun 17, 2004 | 12:29 AM
96ford4x4turbodiesel's Avatar
Click here this might help you
Old Jun 17, 2004 | 12:49 AM
johnsdiesel's Avatar
johnsdiesel
When the CMP Sensor finally goes out it won't let the truck run at all. Intermittant hesitation is usually the first sign of it going out, but once it's out you're stuck.
Here's a couple of links for you:
CMP Sensor Location and Part #
CMP Sensor Removal/Installation
Old Jun 17, 2004 | 06:07 PM
Diesel Daddy
Thanks guys! I may just go ahead and buy one just in case. Actually, it seems that the hesitation really happens as the trans shifts into third gear. I wonder if its the torque converter?
We'll find out tomarrow after I hook my 30' Formula to it this weekend for the first time!
gary.aderhold
50
Dec 11, 2015 05:48 PM
greenexpy
Modular V8 (4.6L, 5.4L)
Jun 29, 2008 02:42 PM
deppdog
1983 - 2012 Ranger & B-Series
Oct 22, 2005 08:59 AM
Farmall Hauler
1997 - 2003 F150
24
Oct 19, 2004 06:51 PM
ksvtwin
Oct 2, 2003 11:51 AM
