General Automotive Discussion
Hot Baja Bug
Old Jun 16, 2004 | 04:02 PM
JimKC's Avatar
JimKC
Exclamation Hot Baja Bug
I am going to swap the VW motor in my Baja for a 1991 3.0L Vulcan V-6. I have no experince with Ford engines and less than that with small displacement V-6s. I plan to rebuild prior to installation but cannot find sources for aftermarket performance parts or info on interchangeable ford parts. Any info on the problems I will probably run into with the electronics (black box) will also be appreciated. My current motor has 85 horspower @ the rear wheels and I am hoping to get between 160-180 hp thru windstar stock exhaust manifolds if poss. One last item. Does anyone know the weight of this motor in stock form with all of the sheet metal in place? JimKC.
