Bronco II Ford Bronco II
Spare and Jack
Old Jun 15, 2004 | 07:30 AM
Ironman255's Avatar
Ironman255
Question Spare and Jack
Hello...!
I do not have the user manual for my truck
Bronco II 1985 2,9l 4x4
Where suppose to be located the spare tire and jack......?
Thanks, Ironman
Old Jun 15, 2004 | 12:21 PM
CherryColaholic's Avatar
CherryColaholic
Well im not sure if its the same as my 89.. but the spare tire would be on the back. The jack is behind the little panel on the rear passenger side footwell. The jack handle is under the hood right by the hood support. Hope this helps.
Old Jun 15, 2004 | 01:09 PM
Johnboy_BoomerSooner's Avatar
Yeah, in 85 the jack is in the same place, right behind the passenger side seat on the kick panel on the right. Just a little square access panel there that pops off, jack should be right inside, handle is under the hood... and the spare is either on a spare tire carrier on the back (if you had a full size spare) or inside in the back behind the back seat on the passenger side (donut spare)... it just stands up back there and has a carpet cover. You said it's an 85... you should have a 2.8L V-6, not the 2.9 unless someone did a swap, 2.8 was a carb engine, 2.9 was fuel injected and was offered first in 86.
Welcome to FTE and good luck!
Old Jun 15, 2004 | 08:13 PM
Ironman255's Avatar
Ironman255
Red face Thanks Guy's
I now know i have to get an little spare to put inside
or a spare carrier to fixe on back of truck (if its possible ?)
i found the jack and the rode
special thanks to Johnboy who's open my eyes, my engine is
really a 2.8L.
wpnaes
May 19, 2013 09:25 AM
ironman540
Virginia Chapter
Jan 20, 2012 05:17 PM
ironman540
WTB - Parts & other
Nov 30, 2011 01:02 PM
Ironman255
Bronco II
Dec 29, 2003 12:19 AM
