Yeah I like the first cage as well, pretty sexy. Yeah sticks only have 30% deposition, whereas MIGs have around 60%. that 70% creates slag and stuff to put dots all around your welds, not to mention the sloppiness of the weld itself, unless your a pro (not Pro).
Fishy, can you use a TIG? Might just rent one of those and make the welds perfect if you can.
ya i am certified tig and mig welder and am working on my stick welding./....what you are saying makes sense! i have to agree!
I think the greatest advantage to MIG is that is keeps the weld cooler, and helps to keep it from cracking. I wouldn't bother TIGing a cage, unless you are using chro-moly..
ya that's the biggest advantage! i think i am gonna use the first pic and model after it but instead of the guards around the wheel wells in the bed i am gonna have a bench seat and i wanna run the back of the cage down and to the outside and tie in to the frame rather than run it to the inside!
Thats for sure. All my welds look like somebody with a cold sneezed on them. Besides, even the best stick stiches don't look near as tight as an equally good mig weld.
A while back I was building an office building and the guy installing the structural steel was sticking some stuff and it looked like it was TIG'd. I was blown away. To say the guy was talented didn't even cover it.
