Exhaust routing question
Old Jun 14, 2004 | 09:56 AM
woods's Avatar
woods
Hi,
I am new to this board.
I have been reading on this and the FE forums for a few weeks now.
I picked up a 70 3/4 ton with a 360 motor that spun the timing chain.
The truck is pretty clean other than a couple small dings.
I am rebuilding the upperend with new cam, heads, edelbrock manifold, 600 holley carb and headers.
Not quite sure what brand of headers I have. I got them in a deal with a pair of heads I bought.
I had originally planned on running 2 1/4 exhaust but it sounds like 2 1/2 works better with the FE motors.
Now for the question!
I have dual tanks and was wondering how everyone is routing the drivers side exhaust?
Run it outside the frame rails? or try to route it to the passenger side?
I was under the truck trying to figure out the best way to go and though I would ask here.
This truck has a C-6 not stick if that matters.
Thanks for the help.
Ken
Old Jun 14, 2004 | 12:57 PM
comet's Avatar
comet
I have mine routed to the pass. side, then both out behind the pass. rear tire. I don't really like it, but it was there when I bought it. You could do the same thing and split it to either side, or both out the back.
Old Jun 14, 2004 | 02:04 PM
71Goose's Avatar
71Goose
I have 2 1/2 Duals with the passenger side going strait back about 6" before the rear tire. The drivers side runs back and is routed in front of the tranny where it continues paralell to the pass. and then back to the pass. rear tire. With that extra fuel tank I wasn't able to do anything other than this but have been really happy with it. I'm using dual glasspacks for a muffler, sounds great. Check out my gallery for photos.
Old Jun 14, 2004 | 02:19 PM
woods's Avatar
woods
Thanks for the responses.
I will run it to the passenger side and probably cut back over by the rear axle and run both pipes out the back.
I plan on running 3 chamber flows or something compatable.
Thanks, Ken
Old Jun 14, 2004 | 11:23 PM
jambroson's Avatar
jambroson
Does anybody know if a crossover is necessary?
Josh
Old Jun 15, 2004 | 02:05 PM
comet's Avatar
comet
Not necessary, but in my experience it helps. I don't have it, but when I upgrade the exhaust, I will.
Old Jun 16, 2004 | 09:12 AM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
It helps to eliminate exhaust pulses and even out left and right backpressures differences..and helps in scavenging... Hope this Helps...Russ
Old Jun 16, 2004 | 02:22 PM
jambroson's Avatar
jambroson
Thanks guys, that helps. Local muffler place want an extra $50 for the crossover. I think I will go ahead and do it.
Josh
Old Jun 16, 2004 | 06:48 PM
1972ford_f-100's Avatar
1972ford_f-100
hey ,wuts better,h-pipe(which i have now)or x-pipe?
Old Jun 16, 2004 | 09:50 PM
moonley's Avatar
moonley
My exhaust runs parallel down the passenger side of my truck (to get by the transfer case and dual tank). I was thinking about putting a crossover in, but I am curious as to whether the crossover needs to attach into each side at the same distance from the manifold, or can I just connect where the drivers side comes over to meet the passenger side? Even if it did make a difference, would it be noticeable anyway? Thanks guys.
Old Jun 16, 2004 | 10:34 PM
Faithful Old Road Dog's Avatar
One thing to consider when just rebuilding the top end is the existing condition of the bottom end. If your rings are a bit worn already, rebuilding the top end creates higher pressures that can create some blowby. Just FYI.
Old Jun 17, 2004 | 05:30 PM
woods's Avatar
woods
Faithful,
Thanks for the concern.
I am replacing the top end mainly because when the chain went it bent 3 pushrods.
I pulled the heads to make sure the pistons and valves looked OK. They looked fine but now I would need to surface the heads before reinstalling them and I got the new ones for a little more than the surfacing cost.
Plus I snapped 5 exhaust manifold bolts and didn't want to worry about rushing to pull the remains out
The cylinders have a very slight ridge.
The motor looks very clean internally. No sludge at all.
The way things look, I don't think the motor has ever been opened up.
The odometer says 000.550 miles. I think the truck is at 100.550 miles.
I plan to build a 390 short block in the near future to replace the existing 360 block. so everything I am doing to the 360 should swap over.
My biggest concern righ now with the motor is that there is one freeze plug that has been replaced with a rubber one and I was thinking about just pulling the others on the sides of the block and and replacing them while everything is out of the way.
Thanks for the info.
Ken
Old Jun 17, 2004 | 05:59 PM
Fomoko1's Avatar
Fomoko1
X-pipe will inprove prformance even more but I suspect that most of the gains will be at higer rpm. Don`t know if the X-pipe will help with the lower end/slower speed torque.
Old Jun 17, 2004 | 06:25 PM
PraiseolderFords's Avatar
PraiseolderFords
fomoko1 is on the right track full blown race applications will realize a difference in top end performance from the x pipe- the rest of us just need the h.
Where to place the h? I have always placed it symmetrically.
Old Jun 17, 2004 | 07:52 PM
BB's Avatar
BB
Ken, I just shot some quick pics of the duals on my '68 here:
https://www.ford-trucks.com/user_gal...1&albumid=4805
