LMAO! Too funny that you went through all that....ok lets try this...hopefully I wont get into trouble for it since email addresses are normally removed from the posts. Send it to...
billp (the @ sign here) avanade.com
I have a guy that does custom metal work for very reasonable prices. I found him on eBay over a year ago and have had no problems. he can do the diamond plate stuff he has the black diamond plate the three bar diamond plate. You name it and he can cut a pattern for you. Mostly I figure out what pieces I need for making what I want, send him the measurements or a template and he sends me the pieces.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o> Look for custmetal@aol.com on eBay or email him direct.
well, at jeffs bronco graveyard, there are OEM tailgate shells for every model of full size bronco. at jeffs, there are three different manufacturers of these shells, so the price will be semi-low. I have not been to jeffs site in a while, but Im sure I saw them there, hope this helps.
Woah, if you could find that... that would be awesome. Any hints would help. I'll order any catalog. I guess I'll drive around with the slick looking BONDO til then, hahaha.
I found a piece to replace mine on my 82 through JCWhitney.com you you're probably getting the rust because the window channel on your back window needs new rubber/felt. The kit is cheap and you can do it yourself. Goodluck, Bill
