have a question
Old Jun 13, 2004 | 11:17 PM
stocky400's Avatar
stocky400
Question have a question
have a 400 big block .030 over. runs strong. but here lately it has been cutting out and backfiring badly out exhaust and carb. can anyone tell me what could be wrong?
Old Jun 13, 2004 | 11:24 PM
grclark351's Avatar
grclark351
does the distrbutor have points in it? or is it electronic?
Old Jun 13, 2004 | 11:27 PM
stocky400's Avatar
stocky400
i believe it has points
Old Jun 13, 2004 | 11:28 PM
fmc400's Avatar
fmc400
MSEE
Points gap could be incorrect, and\or bad ignition timing for starters. Any other symptoms?
Old Jun 13, 2004 | 11:34 PM
stocky400's Avatar
stocky400
that's really the only problem. it started out occasionally, once a week and when it did it would only do it going up hills at hwy speed. and now it does in park when i give it just a little gas
Old Jun 13, 2004 | 11:44 PM
fmc400's Avatar
fmc400
MSEE
What kind of carb do you have?
stocky400's Avatar
stocky400
even though it was backfiring if i gave it more gas it really tried to go. a friend of mne told me it could be trying to vapor lock, but the fuel filter was not real hot i could still touch it.
Old Jun 13, 2004 | 11:48 PM
stocky400's Avatar
stocky400
edelbrock carb should be at least a 600cfm(not a doublepumper) it came with a performer 400 intake and a .280 lift cam
Old Jun 14, 2004 | 05:11 PM
fmc400's Avatar
fmc400
MSEE
I am not familiar with aftermarket carbs and I hope someone else can explain how to fix this on your specific carb, but I am almost sure that it is an enrichment failure if you're sure the points and timing aren't wrong. Manifold vacuum decreases when you punch the throttle open and if you're carb doesn't rich the mixture, you will lean out and get a backfire.
If it were the stock carb, I would say its the power valve. That also explains why it got worse. One of those once-a-week backfires could have blown it out finally and gave you the problem you have now.
Old Jun 14, 2004 | 06:43 PM
danlee's Avatar
danlee
Have you tried the distributor cap and rotor? It sounds like crossfiring. At first it did it under load conditions, now there are tracks and it does it all the time.
Old Jun 15, 2004 | 09:15 PM
stocky400's Avatar
stocky400
thank you everyone for your advice. the cap and rotor was replaced..no change. i have a feeling it is some where in the carb. all there is, is process of elimination.
Old Jun 15, 2004 | 10:36 PM
grclark351's Avatar
grclark351
so, does it have points or electronic? for sure?
