Problems starting in hot weather
Old Jun 13, 2004 | 03:12 PM
audoroh's Avatar
audoroh
hello,
I have a 1995 F150 XLT with 54,000 miles. The engine, a 5.0L 302 is really clean and has been well taken care of along with the rest of the truck. Recently i have had starting problems especially when the weather is hot outside. I have replace the fuel filter, spark plugs and wires, rotar, and distributer cap. None of these have fully taken care of the starting problem. It may be a failing fuel pump, but the truck has never stalled so i didn't replace them yet. Any comments or ideas of things to check would be greatly appreciated. Thanks alot.
Old Jun 13, 2004 | 07:43 PM
trike1946's Avatar
trike1946
Welcome to FTE audoroh. Do you have dual tanks? If so does it happen with both or only one. Is the starter spinning fast enough?
Old Jun 14, 2004 | 04:26 PM
audoroh's Avatar
audoroh
Yes i have dual tanks. To answer your question, the starting problem hasn't happened with either particular tank however. Am i correct in saying that with dual tanks, i also have dual fuel pumps. i have read that if one pump is starting to go out, it will affect the other and both must be replaced at the same time. any thoughts on this or other comments are appreciated. thanks
Old Jun 15, 2004 | 08:29 PM
LxMan1's Avatar
LxMan1
You may actually have 3 pumps. It may have 1 low pressure pump in each tank and a high pressure pump on the frame under the drivers seat. I'm not sure what year that they quit doing this.
I would get a fuel pressure gauge and check the fuel pressure when it starts acting up.
austinkb
1997 - 2003 F150
Aug 16, 2016 12:22 AM
Black Ford XLT
Apr 29, 2016 11:51 PM
2011f250arag
Apr 21, 2015 11:53 AM
cole_sla
Oct 31, 2014 03:55 PM
quakerj
Jun 22, 2014 12:37 PM
